Need help plz L92 harness
the cost around $1550 Its too $$$$
I called up this morning a electrician guy discussing my problem , he said its very easy to convert LS2/L92 harness into LS1 harness ( sound good)
but i dont know if the engine will perform well?
Below Pic of EFI connection selling all LS2/LS7/L92 connector
http://www.eficonnection.com/eficonn..._pigtails.aspx
Not to hi-jack, but I have an L92 w/ VVT, and intend to run a T56 behind it (in a conversion). Does anyone know what my options are besides the Speartech kit?
The Speartech kit seems very good, but its pricey, and this is a budget project.
I want to keep the VVT.
Thanks in advance!
-Shaun-
Thanks in advance!
-Shaun-
An E38 ECM engine harness wired for VVT is the easiest choice. Or without VVT and add a VVT line. The E38 is the two plug ECM. The GTO's came with an E40 3 plug. GMPP also sells a complete harness/computer setup using the E67 ECM, again a 3 plug, but it does not do auto as supplied.
Another choice is MAST motorsports. They recently released an aftermarket VVT ready unit.
