Need help plz L92 harness
Old Nov 11, 2007 | 11:03 AM
Xray's Avatar
Default Need help plz L92 harness
Hi
Guys i got my engine L92 2007 yesterday for a new project offroad truck but without engine harness and computer (PCM).
My question is
What harness can be used for this project?
Is Tahoe 2007 with 5.3 vortec harness suit for my engine ? If not what the Alternative Rather than speartech harness because its too costly almost same my engine price
Here is some pics of my engine .
Guys do you know waht does mean this number in below pic
Old Nov 11, 2007 | 01:06 PM
jw33's Avatar
I know what you mean. The speartech harness looks great, but 17 one hundred dollar bills is a little hard to swallow for a harness and PCM. You have a x58 reluctor wheel motor so you will need to get something from a '06 and up. I've seen just a harness on e-bay go for around 800 and then you could source your own PCM for a few hundred more. The only for sure choice out there right now is the speartech harness though that I know of....
Old Nov 12, 2007 | 08:15 AM
69LT1Bird's Avatar
I hate to break it to you but that block is a 6.0L like the casting says, not a 6.2L L92.
It is either a L76 or LY6 6.0L. The heads are the same casting as the 6.2L L92 engine. Does it have a car or truck intake? PM me the information on the bar code or send me the VIN for the engine and I can get the details.
Old Nov 12, 2007 | 09:49 AM
cam's Avatar
cam
Make your own harness its not that difficult. about 8 wires and your up and running. Have to get a stock harness that will work with your sensors/reluctor etc to start with once you figure out exactly what year/model engine you have
Old Nov 12, 2007 | 11:22 AM
69LT1Bird's Avatar
I always make my own. Get the schematic and a good meter and go at it. I can't justify spending that much for a harness. Plus you learn the system while you are check or tracing pinouts.
Old Nov 12, 2007 | 11:31 AM
Xray's Avatar
Here is the intake pic
Old Nov 12, 2007 | 11:44 AM
Xray's Avatar
Right its L76 or L98/LY6.
Old Nov 12, 2007 | 12:32 PM
69LT1Bird's Avatar
Since it has the car intake on it, powersteering pump looks like a GTO and the L92 heads (casting #12568952 turns into 12582713/14 head) on a 6.0L engine, I would guess that someone already did the h/i swap. What did this come out of? where did you get it?
Old Nov 13, 2007 | 03:15 AM
Xray's Avatar
This engine was pulled from 2007 caprice LTZ with 3200 mile only
I found same engine on lumina SS 2007 with same head number but the harness completely damaged
This kind of cars still Manufacture for Middle east and Australia infact its Manufacture in Australia.
here is some car pic
Old Nov 13, 2007 | 06:33 AM
JBT's Avatar
JBT
Why not buy the following part for a 2008 corvette or escalade from GM:
Harness for manual gearbox: $408
Computer: $207
Pedal $75
Add a fuel pump relay and OBDII port and your set to go.
Old Nov 13, 2007 | 07:30 AM
69LT1Bird's Avatar
I guess I should have asked where you are from.
Old Nov 13, 2007 | 09:21 AM
Xray's Avatar
Computer: $207
Pedal $75
Thanks for advice , i think i'll go with that but looking for the correct part number
Xray's Avatar
Saudi Arabia
Old Nov 13, 2007 | 09:32 AM
69LT1Bird's Avatar
Manual trans, non-VVT engine harness - 15940760
Pedal Assembly - 12835421
ECM - 12612384
Saudi dealers should be able to look up all of these and order them.
Old Nov 13, 2007 | 09:51 AM
Xray's Avatar
ECM - 12612384
Thanks alot , i'll check with GM dealers tomorrow .
How about the best GM online dealer, do you know any?
Thanks again
Old Nov 13, 2007 | 09:54 AM
cam's Avatar
cam
Scoggin dickey is good
http://www.sdparts.com/
Old Nov 13, 2007 | 10:21 AM
Xray's Avatar
You are right they have reasonble price but they have LS1 harness from 2001 upto 2004 which not suitbale for my engine . any how i have send email and wetting for reply .
Thanks for the website
Old Nov 13, 2007 | 01:12 PM
JBT's Avatar
JBT
fred beans parts is also good to deal with.
69LT1Bird
From what car does the #15940760 harness come from?
Old Nov 13, 2007 | 02:33 PM
69LT1Bird's Avatar
2008 Corvette, LS3, manual trans, non-VVT
Old Nov 13, 2007 | 02:37 PM
69LT1Bird's Avatar
Call Scroggin Dickey. They are a dealer. Just because it is not on their site does not mean they do not have it.
