Coolant Crossover tube for high HP setup
Old Jul 8, 2009 | 09:08 AM
Phil99vette's Avatar
7 Second Club
I ws going to go the wegner route but time was working and the corvette tube worked fine. With our block being filled now I wanted to make sure we had the rear tubes hooked up. I'd love to see a pic of how your manifold is setup, I have a pretty good idea though. With the new intake I had plenty of room under the manifold.
http://www.petersonfluidsys.com/plumb_ftg.html
Old Jul 8, 2009 | 10:41 PM
backrdrunner's Avatar
Originally Posted by ROCNDAV
This link doesnt work anymore. Does anyone have a new link?
http://s41657.storefront-solutions.c...l.aspx?ID=3289
Took a long damn time online finding that..enjoy.
Old Aug 8, 2009 | 03:35 PM
sergo's Avatar
subscribed for later use...
Old Aug 8, 2009 | 11:27 PM
studderin's Avatar
why not just run the LS1 4-1 tubes
Old Aug 11, 2009 | 10:16 AM
jegten's Avatar
for those who have used either the corvette or ls6/1 crossover tube, can you guys post pics? also, this seems to be something all built motors should have, right?
i just finished a stroker, and would like to do this before i put it in the car. thanks!
Old Aug 11, 2009 | 10:36 AM
sparkwirez06's Avatar
that's what I was thinking, I have a victor, old lines should work??
Old Aug 11, 2009 | 10:55 AM
jegten's Avatar
probably a dumb question-what are the ls1 4-1 tubes?
Old Aug 23, 2009 | 10:58 PM
BlownVette 2001's Avatar
Early LS1'1 had all a solid pipe to all four steam vents. In 2001, the blocked off the rears and put the front two cross-overs pipes together.
Old Aug 23, 2009 | 11:23 PM
jegten's Avatar
thanks!!
i appreciate it.
now, i need to get one of these or another ls6 front to put in the back for my new motor.
been looking for one, but i guess i have not "search" good enough. lol
Old Aug 23, 2009 | 11:35 PM
thanks!!
i appreciate it.
You get the complete set-up from the dealer for like $30 bucks.
Old Aug 24, 2009 | 12:23 AM
jegten's Avatar
oh!
thanks!
Old Aug 24, 2009 | 04:42 AM
  #32
vettenuts's Avatar
Still don't understand the logic of the mod since it cuts the coolant flow over the combustion chambers, especially the front three.
Old Apr 2, 2010 | 12:28 PM
  #33
Petraszewsky's Avatar
Originally Posted by racecar
You definately need to have those rear ones connected to get the air bubbles and air pockets out of the back of the heads. An air pocket can overheat and crack a head.
I use the LS6 pipe on the rear with a 1/4" heater hose to a T on the front, just like the other Corvette guys above. Never had a head problem on a road race car with this set up.
So 1/4" I.D. heater hose fits perfectly over the coolant crossover tube?? And a 350*F rating is good enough???
Old Apr 3, 2010 | 11:58 AM
  #34
koolrayz's Avatar
Kurt's setup is probably the best marketed solution. Much better look then hacking the stock stuff and running hoses.
http://www.kurturbanperformance.com/...or-system.html
Old Apr 13, 2010 | 08:42 PM
  #35
kelp's Avatar
This seems like an important point. Overlooked. I did this mod, and I believe this logic is sound.
Old May 5, 2010 | 05:19 PM
  #36
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Thanks for the info. I'll be getting one of those.
Old May 5, 2010 | 05:43 PM
  #37
7 Second Club
We're still using a 99 vette crossover tube, its about 1/4" and connects all 4 points.
Old May 5, 2010 | 08:10 PM
  #38
04BlackSilverado's Avatar
Got the part number?
Old May 12, 2010 | 01:37 PM
  #39
LilJayV10's Avatar
subscribed.
Old May 19, 2010 | 06:35 PM
  #40
racecar's Avatar
12568478 is the LS6 part.
