Latest budget 427 developments
Old Nov 17, 2007 | 01:08 PM
hyperion's Avatar
Default Latest budget 427 developments
Hello,
I'm considering an engine upgrade. I've done a lot of searching, but I want to make sure I catch the latest on LS2-based 427 packages.
I know that Katech has their 'budget' 427, but I don't know if you can run L92 heads on it or not.
I've heard that SDPC has a 427 long block, but I can't find it on their website.
I've heard that Texas Speed also has a 427 long block, but their website is hosed.
Are there others? I'm not looking for crazy power. In fact, I'd like to make the car more streetable than it is now with its semi-aggressive LS1. If I could hit 500/500 at the wheels on CA 91 gas and no low-RPM surging, I'd be a happy man.
Any thoughts/opinions would be helpful,
-ch
Old Nov 17, 2007 | 03:24 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I apologize for our website being down. We have our web administrator working on it now, so hopefully it will be back up this evening.
We have our 427 cid LS7 long-block package starting at $9,999 using our PRC ported LS7 cylinder heads with hollow-stem intake valves. We have already built quite a few 427 cid LS7 long-blocks for customers that wanted to use our ported L92 cylinder heads. a 427 cid LS7 long-block with L92 cylinder heads would start in the $9,200 range. If you'd like, shoot me an e-mail at trevor@texas-speed.com, and I will be happy to put an itemized estimate together for you so you can see what the build will cost and what exactly will be included. 500 RWHP would be a walk in the park, even with a very streetable/driveable camshaft.
Trevor
Texas Speed & Performance
__________________
Old Nov 20, 2007 | 04:42 AM
deuce_454's Avatar
sorry to break in... but MAST motorsport has a 427 l92 out that is worth checking out IMHO
Old Nov 20, 2007 | 01:56 PM
gnx7's Avatar
Chris- Mike made 510rwhp/500rwtq with a tiny 236/236 115LSA cam in his 427/LS7 headed/intake setup. Went 134mph in the 1/4 in his FD RX-7 in warm weather. Driveability was perfect.
Save the money and just build a 416ci setup.
Old Nov 21, 2007 | 03:33 PM
silicone boy's Avatar
Our cars are virtual clones, except for the engines. That's why you have to go with the 427. I got mine from Scoggins, but the Texas Speed one is at a great price, and Katech is a great outfit. I used their LS7 Torquer cam. I got 540 RWHP and it was very streetable.
Old Nov 21, 2007 | 10:40 PM
Bink's Avatar
Originally Posted by hyperion
Hello,
-ch
Beautiful car and setup.
Low RPM surging is all in the tune- unless your "on the cam".
FWIW.
Old Nov 22, 2007 | 09:40 AM
VortechC5's Avatar
I have the SDPC 427 shortblock and Livernois stage 2 L92 heads. I am happy with this combination.
I will say though that the support from SDPC is not quite what it could be. The dipstick hole was drilled too large in my block causing an oil leak. Brian at SPDC told me that they were aware of the problem and that they would provide me with a fix. It's been 5 months now and they have not done this. I have called and left several messages and Brian won't call me back.
Other than that it is fine.
Old Nov 22, 2007 | 10:05 AM
davered00ss's Avatar
Moderator
SDPC is a site sponsor. -------------------------------->
Old Nov 22, 2007 | 03:08 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Let us know if we can help! We don't have longblocks on our site because of the HUGE number of combinations available. We've got a handful of head manufacturers to offer you including but not limited to: AFR, ETP, GM, PRC, Patriot, GTP, and World Products. We're offering free freight on ALL orders this Friday through Monday the 26th!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
