NA 550hp combo?
Old Nov 19, 2007 | 10:51 PM
TT LS2 1969 Camaro's Avatar
Default NA 550hp combo?
Does anyone have a high hp combo using L92 heads? Just wondering if it could be done naturally aspirated...
Old Nov 19, 2007 | 11:09 PM
venom ws7's Avatar
Here is what I would do:
TSP 427Ci LS7 with PRC Ported L92 heads also from TSP and good sized cam.
This setup made 560rwhp and 520rwtq a member here 03Busa.
Is your car Manual or auto????
Old Nov 19, 2007 | 11:53 PM
Black FormulaLs1's Avatar
hope you got some deep freakin pockets
Old Nov 20, 2007 | 12:32 AM
Customers car is a manual...no deep pockets either...lol.
I was just curious as to what it would take to do such a thing. Realistically we would do a 408 CID, nice cam (solid lifters), L92 heads, 11:1 comp ratio, 4 barrel intake...hoping to get the most out of the engine, naturally.
Old Nov 20, 2007 | 01:14 AM
jermzz's Avatar
What shop? I take it you know Desean?
Old Nov 21, 2007 | 10:15 AM
Desean? You mean "SS Shawn"? If we are talking about the same person, I don't know him, but I have seen his ride and I know what he has...a nice, quick, fun ride! I do most of my own work, primarily on classic, muscle cars. BUt I know alot of people wanting to do the LSX swaps in their old schools. I thought that 500 is a good target hp to start off with...just curious to know what it takes to do such a thing, without a huffer.
Old Nov 21, 2007 | 10:46 AM
turbo'd stang's Avatar
I'm getting ready to put together a 370" with some PRC L92's. The cam wasn't spec'd for the motor/heads, but I'm going to try it and see...its sitting on the shelf. I would think it should hit 500rw pretty easy.
Old Nov 21, 2007 | 11:40 AM
I assume you'll be running 11:1 compression, ported heads, etc.? What type of intake are you going to run? Carb of fuel injected? How much lift and duration on the cam?
Old Nov 21, 2007 | 11:48 AM
Tad more compression. Heads are ported. Intake is a carb style with BS3. The cam is 248/259/6xx,6xx. It's a starting point. From there, depending on power, I'm going to get a few other cams and see what happens.
Old Nov 21, 2007 | 02:49 PM
Is this a pump-gas set-up? I was looking into a .650" lift cam, heads ported on the exhaust side and gasket matched on intake, 11:1 comp. ratio, 4 barrel intake, Accel Thruster, 1200 cfm throttle body, all on pump gas...if I can get to the 500-550 mark that would be great. Will you be using stock rockers, solid or hydraulic cam?
Old Nov 21, 2007 | 03:25 PM
Brian Tooley Racing's Avatar
Here is one that made 550 RWHP, it's a little harder than you would think.
https://ls1tech.com/forums/showthrea...t=#post6673625
Old Nov 21, 2007 | 10:07 PM
I'm going to see about the pump gas, not sure. I'm going with some shaft rockers. I'm looking into doing a solid roller....talking with Erik (HK Racing) about this. If not, it will be a hyd cam.
I figure if I can made 500rw with a 9:1 396 through a PG, I should be able to do the same with a little smaller motor, more compression and RPM. I got a REALLY good deal on this half completed combo, 3k for short block, heads, intake...so if it makes 450, I'll still be happy.
Old Nov 22, 2007 | 08:04 AM
Black2001z06's Avatar
Is this going in the TA or one of the stangs?
Old Nov 22, 2007 | 08:16 AM
Bmassie's Avatar
Default 550 hp
The new super chevy has a interesting article on building a 550 horse lsx 427 dont know if your interested or it helps
Old Nov 22, 2007 | 09:28 AM
Thanks...I'm always interested in high hp combos...Happy Thanksgiving, fellas!
Old Nov 22, 2007 | 11:50 AM
TA until the 396 is ready....then it goes into the white Mustang.
Here are a couple of pics of the 370 Heads and intake didn't come in. From the looks of it, it should be capable of making some power....
Attached Thumbnails NA 550hp combo?-image_034.jpg   NA 550hp combo?-image_031.jpg   NA 550hp combo?-image_030.jpg   NA 550hp combo?-image_029.jpg
Old Nov 24, 2007 | 06:33 AM
dochall22's Avatar
Why not use the LSX block? would l92 heads still work?
Sounds like some money is going to be spent regardless, if u use the new block you'll have room for more later on, and 500hp would be a walk in the park!!
Old Nov 24, 2007 | 10:11 AM
Yeah...that's a bit over-budget for my customer...that LSX block accounts for about half of the whole build-up, unfortunately, plus there's a 6.0L readily available.
Old Nov 24, 2007 | 10:17 AM
dochall22's Avatar
well - good luck with the build, let us know what u finally decide on!
