The LS9. Pictures and full details
Don't get me wrong, I love that GM has gone this route. Like the article stated, they had to go FI to get past the 500hp barrier and maintain long term durability.
I'm going to assume you meant 600hp.
It will be interesting to see what this block with the windows can take. The LS6 blocks are weaker than the LS1 blocks because of these windows, but it will be interesting to see how this fillet radii helps.
At maximum output, the fuel system needs to be able to supply 58 g/s. Injectors that can supply enough gasoline to feed an engine with this much power tend to be hard to control at the low flow rates required at idle. To help achieve this, a separate fuel system ECU is mounted next to the fuel tank. Based on demand it can adjust the fuel pressure to either 600 kPa at high speeds or 250 kPa at low speed.
What's the current limit of our PCMs? This dual PCM system sounds interesting even though I don't know that much about it.
What's the reasoning behind the removed material on the main caps by the side bolts? I'm not an engineer yet, but it's logical that the less material you have the weaker it is. Is it made of some special material that enhances strength greater than something like out main caps that still have that material?
Are those completely new head gaskets or are those the new GM MLS on the LS3?
An 11 rib belt drives the blower, water pump and power steering pump
That's really nice. It kind of sucks they couldn't utilize a seperate belt for the blower, but with the additional pulleys it will help with belt wrap.
Anyone know any specs about the rods? I know they are titanium, but are they the same specs as the LS7 or are they different? Hopefully GM will do what they did before and price them like the LS7 rods. If they are nice I'm definetly going to get a set before the price jumps up 1000%.
The rods are completely different than the LS7. They are Pankl and they will be outrageous.
Well, don't be surprised if the blue oval boys throw the same back at us. That's all. Personally, fast is fast, power is power. There's more than one way to skin a cat.
yep!
