L33 aluminum 5.3 block compared to an LS1 Block
I just got a 2000 LS1 short block with excessive blowby in number 7 for $200. If you shop around you can find things really cheaply.
LS2 Conversion info:
https://ls1tech.com/forums/generation-iii-internal-engine/659189-ls2-conversion-info-inside.html
Its amazing the kind of information that gets posted when people do not know 100%. I have an aluminum 5.3L sitting in my garage. Externally it is identical to an LS1 in every respect. All external bolt-ons will bolt on without issues. The sleeves have the same O.D. as the 5.7L engines so it can easily be bored to be a 5.7L engine. The crank and rods are the same as an LS1.
Andrew
Andrew
4.8 all the way to 6.0 are the same block just different bores you can take a 5.3 and resleve it and bore it to a 6.0 or you can just get a 6.0 liter iron block for $300 which would be cheaper but its up to you
The Trailblazer 5.3L have the dipstick in the pan so the block does not have a hole in the block. The block has the dipstick boss cast into it but it is not machines.
Andrew
Andrew
