head and intake is all i need to choose
Old Jan 15, 2008 | 12:02 AM
  #41
Drew04GTO's Avatar
I know its your car and you're going to mod it the way you want. But I think you can build an iron block 370 with afr heads and a single turbo/truck manifold setup and make quite a bit more power than you set a goal on, plus have money left over for built rear end, transmission and a box of bandaids. It would be 100% stock reliable if you kept it reasonable and your mom could drive it. I love the crap out of cammed ls1's and how they sound, but I think I can make more power with a much more reliable valvetrain without losing anything noticeable in torque, for a lot less money, and last a lot longer. If you're seriously planning on going FI on this soon do it once and do it right. Many of the parts you'd use to build it n/a are trash in an FI motor (pistons, cams). So you're looking at multiple motor builds.
(flamesuit on)
Old Jan 15, 2008 | 08:28 AM
  #42
tcr98taws6's Avatar
The bottle is a carbon fiber 12.5 pound, it's good for about 6 passes.
What size stall are you going to run in your A4? Locking or unlocked converter?
Old Jan 15, 2008 | 09:15 AM
  #43
needadvice's Avatar
Well, since it will be doing just highway pulls i was figuring a 3200.????
To be honest-- i don't really know what advantages/disadvantages there are with locked and unlocked
Old Jan 15, 2008 | 09:16 AM
  #44
needadvice's Avatar
(flamesuit on)
Damn...you have a good point. FOR UNDER 14K?????? How much could all this be had for? And i need my a/c so what turbo kit will be good? i knew i would get other good options for this, i'm still open to anything.
What power on pump gas would I be lookng at and be reliable?
Thanks.
Old Jan 15, 2008 | 11:14 AM
  #45
tcr98taws6's Avatar
A 3,200 stall and a sheetmetal intake is a total mismatch...........
I suggest you use a sponsor from this board and let them guide you thru your build.
Old Jan 15, 2008 | 12:15 PM
  #46
needadvice's Avatar
i already have an engine builder, tranny and rear-end, just trying to figure out a powerplant to spend my money on, builder will build whatever I want. Just want some opinions here before I choose. The stall issue i never really thought about with a sheet metal, didn't know they were mismatches.
well assuming I went with that single turbo 370ci that "Drew04GTO" mentioned, then what would be a good stall for highway runs?
Old Jan 15, 2008 | 02:32 PM
  #47
Johny GTO's Avatar
(flamesuit on)
What setup would you use if you did what you are suggesting? could you list the cost of each step please.
Old Jan 15, 2008 | 03:27 PM
  #48
tcr98taws6's Avatar
3,200 stall with an intake that is not reaching it's effectiveness until after 6,000 rpm is not going to help you after each shift point, especially in the 60 ft. You will either go up in smoke or run like **** at launch.
Kinda like running a tunnel ram with twin carbs on a street engine.....looks great but isn't very effective. Sounds like you are completely attached to the sheetmetal intake no matter what.
Old Jan 15, 2008 | 03:36 PM
  #49
needadvice's Avatar
Not after hearing from you guys. I just heard from alot of people that the LS7 was probably the best intake for our engines right now, all around. but since high rpm's are what I want and a sheet metal shines at high rpm thats what I thought i'd go with to allow the heads to perform at their best and not be choked by the LS7 intake.
anyway, i'm liking the sound of going 370ci iron with a turbo kit and staying well under my budget. i'm open for anything. 700-800 RWHP would be great and still have a car that drives well in the city for daily stuff.
Old Jan 15, 2008 | 06:49 PM
  #50
Drew04GTO's Avatar
Would get these parts from SD.
Bare 6.0L block ~$700
Diamond dish pistons ~$635
Compstar rods ~$600
ARP main and head studs ~$190
GM Cadillac lifters ~$290
Manley chromoly pushrods ~$17 ea.
Rollmaster billet heat treated timing chain set ~$115
Federal Mogul competition series bearings ~$160
AFR 205cc heads ~$2300
Head/cam gasket package ~$250
These parts from Thunder racing
Blower cam ~$390
TR ported melling oil pump ~$150
Home built turbo setup
Tial V60 wastegate ~$539
Tial blow off valve ~$250
Borg Warner S80 ~$1700
6.0L truck manifolds ~$200 refurbished
custom y-pipe with turbo flange and manifold flanges ~$400 at the most
Intercooler $~1500 for a good core
Random intercooler piping/connectors/clamps $800-1000
4" exhaust from turbo back ~@800-1000
Fuel system is going to have to be something big with a return line plumbed in. As this list sits its right at about $12,500. However a lot of money can be saved in areas like cylinder heads. You don't NEED AFR heads to make good power on an LS1 with boost, it helps, but mostly is just listed to say that this might not have issues with pushing water.
Old Jan 15, 2008 | 08:14 PM
  #51
Beast96Z's Avatar
You should PM "BeardWS6", He has a beck sheet metal on a 408 that is somewhat a street car. Ask him how he likes it. He had a FAST on it so he would be able to give you good insight.
Old Jan 15, 2008 | 08:16 PM
  #52
needadvice's Avatar
Compstar rods ~$600
Blower cam ~$390
How about ported L92 heads with an L76 intake? Also, where do you get the actual piping from that makes up the turbo kit? Or just use an OFI single kit????
Old Jan 15, 2008 | 08:30 PM
  #53
Johny GTO's Avatar
thank you drew.
Old Jan 15, 2008 | 10:09 PM
  #54
Stang's Bane's Avatar
I think he loved it. His 4l60e hated the rpms where it wanted to really shine though...
Old Jan 15, 2008 | 10:24 PM
  #55
Drew04GTO's Avatar
L92/L76 seems like it would be awsome for boost although I can't say much on what it would require as far as a cam is concerned. I also can't vouch for cylinder head deck thickness. I know at higher boost/cylinder pressures LS1's will push water because stock head decks tend to flap in the wind. On the piping, if you go the way I listed you'd have to fabricate it yourself, or take it to a local shop and have them do it. If you are local to Dallas I'd be glad to help you out with this.
Last edited by Drew04GTO; Jan 15, 2008 at 11:53 PM. Reason: Forgot stuff about piping.
Old Jan 16, 2008 | 09:14 AM
  #56
needadvice's Avatar
Oh right, you mentioned the pushing water issue, makes sense to spend the extra $700-$800 for the AFR's over L92's. Not local to dallas, I think the OFI kit would be great its a done deal and proven good, right?
But what intake would be good with the AFR's?
Old Jan 16, 2008 | 09:44 AM
  #57
tcr98taws6's Avatar
In a boost situation you could use the sheetmetal intake without low end issues.
Old Jan 16, 2008 | 09:46 AM
  #58
needadvice's Avatar
That i know. I was just talking N/A with the sheet metal and losing the low/mid.
So what the cheapest, yet good intake to use with the AFR's and boost?
Old Jan 16, 2008 | 10:12 AM
  #59
Drew04GTO's Avatar
Edelbrock victor jr. efi and a throttle body elbow
Old Jan 16, 2008 | 10:15 AM
  #60
Or a ls6. If you are not looking to go over 700-800 RWHP, many,many people jsut stick with the ls6.
