Old May 18, 2016, 06:11 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
ls1 to ls2 swap
Old Nov 25, 2008 | 09:42 PM
HSV-GTS-300's Avatar
I know 12600325 cover with brown sensor will work with sprocket 12576407 and Cam Chain Damper 12588670.
Dont know what difference there is between 12600325 and the 2008 LS3 front cover 12600326 is all.
Old Dec 6, 2008 | 11:57 AM
camarorat's Avatar
Will the 325 cover work wiht any LS2 chain set (aftermarket)?
Dont know what difference there is between 12600325 and the 2008 LS3 front cover 12600326 is all.[/QUOTE]
Don't know if this answers you question, but the 326 is set up for DOD system (Displacment on demand). I don't know if you can use it wiht a LS1 PCM, or for that matter even a LS2 PCM that didn't have DOD.
Old Jan 14, 2009 | 10:32 AM
Big Bird WS6's Avatar
ok i have a cover with a yellow/brown sensor in it. will that work with the ls1 computer?
and my spocket has is the 2x version. with this work with a ls1 computer?
Old Jan 14, 2009 | 10:44 AM
jmilz28's Avatar
https://ls1tech.com/forums/new-produ...l#post10840900
Conversion box - problem solved.
Old Jan 14, 2009 | 11:17 AM
i have a 24x wheel. i don't want that. i would rather buy a new sensor.
Old Jan 15, 2009 | 08:15 AM
this really doesn't help
Old Jan 15, 2009 | 12:46 PM
For LS1 computer and LS2 cam sensor the outer wires need to cross somewhere.
[/QUOTE]
explain this.
so i have a ls1 ecu. so form my factory harness to the new cam sensor i need to switch the out side wires?
Old Jan 15, 2009 | 01:04 PM
Detroitmuscle's Avatar
You will have to get or make an extension from your harness to the relocated knock sensors (they get moved to the sides of the block itself) and also the cam sensor (which is now located on the timing cover), that diagram shows that the early batch of Katch conversion harnesses had the brown and pink wires to the cam sensor switched and that is how you would correct that problem.
Old Jan 15, 2009 | 02:16 PM
i know about it getting moved.
i have the cover and the sensor.
all i am saying is. do i still need to switch the wires?
or does "a" go to "a"
and "b" to "b"
and c to c.
or what?
like form my factory harness. to the new sensors. does the the wires switch?
thanks
Old Jan 15, 2009 | 11:50 PM
Bouvs's Avatar
you there was a point where i thought I had this figured out but now I'm lost again... someone has to dumb all this down and start from the beginning... lol sorry real newb here
Old Jan 16, 2009 | 10:34 AM
^ ^ ^ yeah please dumb it down. pretend i am a ford person.
Old Apr 17, 2009 | 01:16 PM
  #32
CalSpeedPerformance's Avatar
The 326 timing cover will cause problems with starting and throw a cam sensor code on a LS1 vehicle.
Old Apr 17, 2009 | 01:26 PM
  #33
Does swapping the 2 outer wires over fix the problem ?
Old Apr 17, 2009 | 09:23 PM
  #34
I tried that and didnt work.
Old Apr 17, 2009 | 09:43 PM
  #35
Haans249's Avatar
Anyone check the part number on the cam sensor? I have an extra one from an LS2 front cover if someone is interested. Its the black one, not the whiteish/yellow one.
Old Apr 28, 2009 | 12:06 PM
  #36
elky489's Avatar
ok i have a 2005 ss sil.It has the stock motor but customer installed the ls7 cam that doesnt have the reluctor built intot he cam.What cover and sensor do i need to run,will the crank reluctor in it function or does that have to be changed?Please let me know thanks....Also have they fixed the jumper harness problem yet or do they still have to be flip flopped.
Old Apr 29, 2009 | 12:39 PM
  #37
Elky: You use the 325 cover, with correct upper timing sprocket, with the wires swapped.
Old Apr 29, 2009 | 06:11 PM
  #38
elky489's Avatar
jim what harness or do you just extend the stock harness?
Old Apr 29, 2009 | 10:48 PM
  #39
You can just extend your stock harness and cross the wires, or buy a plug'n'play extension harness that crosses the wires for you and plugs right in.
Such as this:
http://store.katechengines.com/share...CS=katech&All=
Old Aug 28, 2011 | 01:30 AM
  #40
64nova_wagon's Avatar
So how has this been working? Is it really worth going to a ls2? benifitts?
