Old May 18, 2016, 06:11 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
ls1 to ls2 swap
Old Jun 12, 2012 | 11:16 PM
  #41
Bumpin' Yota's Avatar
Ok Im tossing my hat in on this one:
I plan on running a 4.8L Gen III vortec engine swapped into my 4runner. I want to run a LS2 cam (gen IV) in it as they are cheap as hell.
I know that I will definately need a new timing cover/sensor assembly (325 as previously mentioned) as well as a LS2 timing chain/gear set.
IF I am understanding this correctly, there are TWO different LS2 timing/gear sets? The earlier set will reproduce an LS1 signal and the later will not?
IF I use the earlier gear/timing set (circa 2005) will I still need a 24 reluctor wheel on the crank and the associated sensor, or would that change only be needed for the newer LS2 gearsets?
Old Jun 12, 2012 | 11:28 PM
  #42
OK!!
courtesy of LS2.com I dug up some VERY revealing info!
http://www.ls2.com/forums/showthread.php?t=834483
Gen III engines have a 24x reluctor wheel built in as well as the 2005 LS2, thus a 2005 LS2 cam gear can be used with a LS2 timing cover and sensor. After 2005, say hello to the 58x reluctor and the new timing gear. The big question is, will the newer sensor/timing cover (325) work with the older 2005 LS2 cam gear, or must it be the 2005 circa sensor?
Old Jun 12, 2012 | 11:37 PM
  #43
HSV-GTS-300's Avatar
Leave the 4.8L Gen III vortec crankshaft alone, it already has 24x reluctor wheel.
Only use an LS2 stock GM cam from 2005, it will have 3 bolt holes for the cam gear to bolt to.
Use 2005 LS2 cam gear Part No 12576407, 3 bolt holes, 1 timing lump.
Yes, the newer sensor/timing cover (325) will work with the older 2005 LS2 cam gear.
Old Apr 3, 2013 | 06:38 PM
  #44
svtwhat?'s Avatar
Ok im confused... GM performance parts, and lingenfelter sell the cover # 12600326 as a ls2 timing cover. This is not the part number that you guys state in previous posts. Is this an even newer superceded part number. I bought the 24x cam gear, and am wondering if this cover will work now as this is the one in my posession.
Old Apr 4, 2013 | 02:43 PM
  #45
anthony.fatica's Avatar
I'm kind of in the same page as you, this has a little bit of helpful info on it... http://www.ls2.com/forums/showthread...hreadid=626014
EDIT: Well it has alot of bit of helpful info, but a little about what you're asking...
Old Feb 17, 2014 | 11:00 PM
  #46
LilJayV10's Avatar
Sub'd. If things go right I'll be doing this swap in the next month or so.
Old Feb 18, 2014 | 03:22 PM
  #47
Let me know how it goes! I'll be doing mine as soon as the weather breaks here and I can get my car out of storage. I'm just finishing up assembling the engine
Old Feb 18, 2014 | 07:18 PM
  #48
LilJayV10's Avatar
Will do. It's not a sure thing yet. A good friend bought an LS2 out of 05 Vette from his brother in law for cheap. He says he plans for it but his wife is demanding he sell it.
The engine is complete. I figure I can sell the Batwing oil pan and LS2 intake and recoupe some of my money.
Even stock using a LS6 intake and 1 7/8 headers it will make more than an LS1 w/ a cam.
I already have the LS2 timing set from my LS1 build. I "think" all I need is to relocate the knock sensors and either buy or extend the knock sensor and cam sensor harness myself.
I'm pretty sure I can reuse the timing cover but might have to get a different cam sensor, that part I'm not 100% on.
Old Mar 16, 2014 | 05:34 PM
  #49
A.R. Shale Targa's Avatar
Oh Snap....LilJay got some inner gears a turnin'....
Great info in this thread....2 must be better than 1 right ??....
Old Mar 16, 2014 | 09:26 PM
  #50
LilJayV10's Avatar
LOL. Well my LS2 deal fell through this afternoon. My friend decided he isn't going to sell it.
I guess I will be going with my backup plan now.
Old Jan 10, 2015 | 06:27 PM
  #51
ls1jorge's Avatar
Bump anyone else knows what's needs for a ls2 into Fbody?
Old Jan 11, 2015 | 08:15 PM
  #52
xGnarciax's Avatar
As far as accessories go everything bolts up fine. You'll need to drill and tap new threads on the sides of the block to fit ls1 knock sensors and run a knock sensor extension harness and run a cam extension harness to reach the cam sensor on the front ls2 cover. You may have to run a convertor box for the crank if it has the 58x reluctor. Hope this helps.
Old Jan 12, 2015 | 04:34 PM
  #53
ls1jorge's Avatar
Thanks Man Yea i was able to research more after seeing your post, i just bought a 07 ls2 shortblock. Gonna go ahead & swap it in
