Got an ls2 402 built
I got a 402 built with afr heads, questions
And i have AFR 205s on my current stock block. I should be able to open them up some to work on the 402, correct? I saw tony mamo mention using 205s on a 402 and getting 560rwhp out of them.
Do you have to open them up to get them to work? If not, how much of a choke will they put on a 402 if I do not open them up? This 402 is a low compression motor for a twin turbo set up.
