XER281HR cam installed in my C6!! its too roughy
That's a pretty healthy cam. Specs are: XER lobe 232/234 .595/.598 112+2. According to Comp here are the characteristics; "mild-rough to rough idle. Race only." I had a similar cam in my heads/cam setup (232/232) and it loped pretty good. Raising the idle, adding a little airflow and increasing the timing will help, but it's still going to lope.
ok now as what i was tould from comp cams that this cam will not be too roughy !!!!
but its dam roughy the rpm range u can feel a huge diffrence from 2000rpm untill 6500 rpm .
some told me thats its all from the B&B cat back thats why ur cam is acting roughy .
check the video and listen to the cam is it normal??
http://www.youtube.com/watch?v=6YOvQRKEYPs
hmmm im not pleased with my project set up u can see why
http://www.youtube.com/watch?v=GXZEG1Lg8do
my et 225head + fast intake + cam + ther160 + cat back
maybe its from the tuning but the tuner isnt bad ![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
will when i called comp i told them i want a street race cam with a higher lsa 114+1 to keep the cam sound normal .
i did have the magic stick 3 before and i sold it cuz of its aggressive sound .
well i did sold my car now .
i heard that the new owner did install a magna charger on the c6 .
thanks everyone .
thanks everyone .
