L92/LS1 valve centres?
Old Apr 7, 2008 | 02:08 PM
lstvr's Avatar
Default L92/LS1 valve centres?
I am putting Dart 225's onto L92 Mahle pistons with cut outs, does anyone know if the valve centres have been shifted with the larger bore of the L92 block? Therefore need to machine the pistons. Cheers
Old Apr 7, 2008 | 04:19 PM
WKMCD's Avatar
Probably your best source for info on the Dart heads is banned from this forum.
Old Apr 7, 2008 | 11:41 PM
racer7088's Avatar
Arrow
The reg 15 degree LS1 heads like the DARTs have tighter valve spacing than the L92 does so the reliefs will be different.
Old Apr 8, 2008 | 02:36 AM
lstvr's Avatar
Ok, thanks guys, i will have to get the pockets on the pistons elongated before build then. I have access to an LS3 stock motor over here so i will measure the top of the valve stems to get the difference. Valve clearance is not an issue at the moment but if i go bigger cam in the future i'll be glad i did it. Cheers
Old Apr 8, 2008 | 03:33 AM
racer7088's Avatar
yes I have had to cut the L92s on regular pistons but not the reverse. It will be easy since only a small amount will have to be cut since your other reliefs are already there.
