Diamond or Wiseco Pistons
And thats not to say there is anything wrong with any of the others, this is just our choice of piston. We do a lot of FI and N2O applications.
Does anyone think there is an advantage to using higher compression height pistons (for 3.622" stroke) for a high psi boosted motor vs low compression height (1.1") for a 4" stroker.
I am worried about Piston rock when I have a deeper dish shaped like the combustion chamber. Should I be worried?
I step up and use CP or BME in all the hardcore big dog builds...
CP LS7 on the left.... BME SB2.2 on the right
On the other hand I have not had an experience with Diamond but I see alot of boosted guys going with them in their builds. Do they build a better piston for boost or something? Either way I believe they both manufacture a great product for us to enjoy our hobby of cars and racing.
My builder will run up to a 250 shot on Diamonds and 300 or more with Wiseco.... the Wiseco has thicker ring-lands.
especially dealing with that Brian dude is extremely rewarding - even when I needed some special made LS3 pistons for a 427 build a few months ago. Due to the complexity that they were custom specced and ordered through Canada through a good guy no longer with us, Brian stepped in and helped out quickly and had good turn around in a few weeks only. I remember having to wait for 3+ month on some special pistons from Ross or JE and usually got them when season was over which sucks when you currently lead in points............
Brian, greetings from overseas.......
Thanks,
Jeremy
We are running a 500 shot.
Robin
[IMG]
[/IMG] I'd like to try the mock up piston approach for a set of customs sometime, in few examples may not need ie an exhaust relief.
