Diamond or Wiseco Pistons
Robin, do you leave the very thin edge on the pistons where the valve reliefs come into the piston (outside edge)?
I found that when we get the tune razor sharp(hot) that it likes to knock that edge off for us. lol
I also noticed the original set that Erik did for me had that egde removed.
Just another reason why I say he is "The Man"
Not the best picture, but I only got a few miles out of my wiseco pistons. This is on my 440. Wiseco had a bad batch of 440 pistons shipped out. The pistons cracked, I think that A&A had the same problem with wiseco also. They sent me a new set I hope that new pistons hold up.
If I had a penny for every set of pistons I'd seen that had lifted ring lands I'd be fantastically rich right now! We've used Wisecos and also shelf Wisecos in several 1000+ RWHP deals and Diamonds as well and have yet to get a "bad batch" ourselves yet even with 4-6 engines going out a week for several years.
Now we have had lots of guys burn pistons up down here in Houston with every piston brand imaginable. We also have seen several pistons from one maker named above take out one side of the pin boss on their blower and turbo pistons but it isn't Wiseco or Diamond.
That being said, 440's are becoming more common and it's Wiseco's job to make pistons stronger through evolution, but Mother Nature gives us and our competitors our lumps.
A design change was made for 2009 to our LS line to move from 1/16, 1/16 (about the same thickness as a 1.5, 1.5mm) top and 2nd rings to the 1.2 1.2 gfx ring. This give us another .030" worth of "real estate" to apply to the top ring land. Does this make the piston unbreakable-no, but it allows the customer a wider tuning window.
The 2009 design is what we sent to Mike a few weeks back. Although the parts aren't bullet proof, the lands are about as thick as a quick wearing .043 ring pack and will last many times longer. -Brian Nutter
I have used your pistons on my 427 without any problems, and have been very happy with them. My car is NA no nitrous/boost, so the new pistons should work just fine.
This is when I was still using my 427. The motor is now in another car still running strong.
http://www.modified.com/uscc/sccp_06...rx7/index.html
[/IMG]
