LS2 402 What cam to use?
I've cammed both a Trv2 (232/234 113LSA) and Vindicator (240/244 114LSA) in my 408....liked them both.....so next is something right in the middle...236/240 112LSA...it sounds like you are wanting more of a street car, go with something 240 or below...
Stroker2112
Stroker2112
So far I am looking to get the MS3 cam which is a 237/242 .603 .609 w/ a 112 LSA. This will be pretty close to what you have in your car with a little less lift on the intake. I hope this will work good for my setup. I flowed my PRC LS6 heads and they stoped flowing past .600 lift on the intake. They did put down 305 @.600 lift on the intake side though so I am pretty happy.
is it just me or is your 1/4 mile slow and #s low for your 418cid engine?
no offense in any way...
im asking because i was gonna go with a 402 with a similar sized cam, but with a fast 90 ported and kooks it should be over 500+rwhp with a 402, m6..
i know ure a goat, but ure also a 418...
Race your car!
For a car you will daily drive, keep the lift under 610 if you can, I just changed the valvesprings on my 402, ans was rather surprised that after 50 track passes, probably 20 dyno pulls and 500 street miles they were pretty weak. But, I'm runnign s realtivly agressive cam with over 610 lift, I'll leave it at that.
I'd look for something in the mid 240's duration wise around 590 to 600 lift
Oh, and that gto with the 418, I dunno if the car's full weight with the safety gear it needs with the nitrous on, but if it is, that's a solid 4200 lb car at that point, so I don't think it's too much of an underachievr. Those cars are really REALLY heavy, and the drivetrain in them, is worse then a 10 bolt f body, it's a real step backwards for drag racing.
well Im sure the rearend is stronger than the 10 bolt right? BUT I do realize it eats up more rwhhp due to IRS, but the 10 bolt doesnt eatup a lot of Hp... so I wasnt sure what ure saying there. but I do understand if his times arent that fast due to weight and not hooking up with IRW or whatever. Buttt, the hp he made still seems a tad low to me. Im just wondering thats all...
#34
Just remember "great drivability" is subjective and great drivability for weekend use and as a daily driver are two different things. People pull larger cams all the time when the car is no longer fun to drive. A well chosen smaller cam can produce 95% of the RWHP of a larger less drivable cam. Current fuel cost may also need to be considered if this is your only car. I like medium size cams that make good power and can be driven anywhere and don't waste the springs in 10k miles.
My car makes good numbers and is a blast to drive. Tip-in is insane. It will roast the rears from 2k RPM where it makes 380 RWT and over 400RWT afrom 3k up. I drive the car in DC rush hour and take it on 500 miles trips. Specs in sig.
My vote is a 236-242 112 +0 with your setup. Stay with not too aggressive XE-R lobes. Set it up at 11.0:1-11.2:1 compression and enjoy.
My $.02
Kevin
My $.02
Kevin
#35
the cam in my 402 is very simalar i have not been able to drive it yet, or get it tuned (need to get the F***ing body work done first) It hunts for idle now, but i am sure that i will be happy once i get it tuned.
#36
#38
i would go with a cam that was specifically designed for a stroker/big cube motor.
for good power and driveability you might want to consider our SS2 cam.
238/244 114lsa 605/612 - we've seen excellent driveability out of this cam, and over 500rwhp on 400+ cube motors (a few through automatics!).
I will be buying a 402ci LS2 short block from Texas-Speed sometime next week. I have new ported lS6 heads w/ Gold PRC's that I will be using. I am thinking of going with a MS3. What do you guys think? I want my car to be some what easy to drive. I might be using this car for a daily driver. How streetable will a cam like this be compared to the MS4?. My car has almost all bolt ons and I will be using the LS6 intake and Ported TB for now untill I can afford a 90/90 setup. What kind of HP do you guys think I should be expecting with a setup like this. Thanks for any Help or Info.
#39
#40
For future reference this cam is awesome. it drives so nice around town and pulls crazy hard. Thanks to TSP, CMS, and my buddy Kendall to help making this all come together.
