cam choice "wild" 427 LS3?
Old Apr 20, 2008 | 02:37 PM
coolchevy's Avatar
Default cam choice "wild" 427 LS3?
we built a 427 stroker based on an LS3 block but the power is not what was expected, I'd like to hear cam choices to get this as radical as possible as neither idle quality nor drivability is the main concern. It should be able to be driven on street of course but it can have its edges........
here the built list:
-LS3 block with 0.005 cleanup, 11.8:1 CR
-4.1" stroke crank
-ETP 255 CNC heads
-FAST90 intake + 90mm LS2 TB
-cam 114 LSA, 248/256 @ 050, 0.62/0.63 valve lift w/ 1.7 Harland Sharps
-full length headers, VaraRAm with 100mm MAF
tune is spot on but it feels like there could be a lot more.
what would one expect regarding expected output with above combo?
Old Apr 20, 2008 | 03:21 PM
Tom@SpeedInc's Avatar
what kind of power did it make?
where did power peak at?
havea copy of the dyno graph?
automatic or M6?
Old Apr 20, 2008 | 03:30 PM
coolchevy's Avatar
have a sheet but on the workshop laptop. On a Mustang like dyno it had 455 rwhp @ 5800 rpm and just 440 rwtorq @ 5300. It is a M6
i was expected 500+ rwhp
Old Apr 20, 2008 | 03:47 PM
bandit1's Avatar
WOW something dont sound right my LS7 based 427 build up which used a set of stock off the shelf L92s and L76 intake with a mild 238/254 cam and a stock 99 78mm maf made 505 rwhp and since I have changed to the ported LS7 heads adn ported LS7 intake and a mid 240 in high 250 650 lift 110 lobe sep cam and no maf speed density tuned Im making alot more now.
Old Apr 20, 2008 | 05:21 PM
03 BUSA's Avatar
Tsp 263/270
Old Apr 20, 2008 | 05:35 PM
Wnts2Go10O's Avatar
is it acting weird? also you hve to remember md's read lower than dj's. if power really is down take a look a the tune.
Old Apr 21, 2008 | 12:42 AM
coolchevy's Avatar
no acting weird at all, very enjoyable to drive just low power output which does not seem to fit actual performance. Tune is spot on i'd say
Old Apr 21, 2008 | 03:08 AM
99blancoSS's Avatar
How much more did you dyno?
Old Apr 21, 2008 | 10:54 PM
needadvice's Avatar
Go to another dyno.
Thats not just low on power, its horribly low. You're 100-160 hp low, depending on who built it.
There's a bunch of head/cam/exhaust C6 Z06's putting down 580-615 RWHP through M6's.
Old Apr 22, 2008 | 07:43 AM
325trooper's Avatar
I don't think the cam is your problem. I made way way more power with an LS1 427 with ported 6.0 truck heads and slightly smaller (244/250) cam. Put it on a Dynojet and see what it does.
Old Apr 22, 2008 | 08:38 AM
78novacaine's Avatar
i would think that with a cam that large you would need to spin a lot more than 5800 rpm's to get full power out of it, i mean, stock cam cars with full exhaust peak about that high, but i would think that cam would need a LOT more rpm
Old Apr 22, 2008 | 11:50 AM
KingSS's Avatar
Do a compression test, I don't think a cam is gonna pick you up 100hp. Are those LS7 etps? If not you might try grabbing some LS7 heads, for the 427's they seem to do pretty well. 455 on mustang dyno would ~500rwhp on a dynojet, I still think that might be a little low for a 427 with an aggressive heads and cam setup, good luck finding the hiccup.
Old Jul 11, 2009 | 08:40 PM
GoFast908Z's Avatar
any updates on this?
Old Jul 11, 2009 | 10:23 PM
Dutchman427's Avatar
subscribing...
Old Jul 11, 2009 | 10:54 PM
LS1-NAVY's Avatar
seems like alot of ls3 427 seem down on power lately
Old Jul 12, 2009 | 01:32 AM
GoFast908Z's Avatar
I'm trying to figure out that very thing with mine.
Old Jul 12, 2009 | 11:41 AM
UVETTYA's Avatar
That's not very encouraging. I'm putting a NA Ls3 427 with an Ed Curtis custom grind CAM, AFR 225's, ported FAST90, 48# injectors in my '04 Z and it should be ready to dyno by mid week. I better get 520+.
Old Jul 12, 2009 | 11:49 AM
Jimbo'sZO6's Avatar
I bet you'll get damn near 550 Steve,,,,,remember, it's all about the combination of parts, and you got the right cam and heads for the job!
Jimbo
Old Jul 12, 2009 | 11:55 AM
UVETTYA's Avatar
Jimbo
Thanks Jim. I hope you're right buddy.
And thanks for relaxing my face.
Old Jul 12, 2009 | 12:07 PM
Jimbo'sZO6's Avatar
No worries brother! Ed C. knows his *****! Getting the heads and intake ported IS going to make it all work together! You are going to be pleased, especially when you get it to the track!
What oil are you going to use for break-in? I'm still running Rotella in mine and will continue to use it until I hit 5k miles. (at 3300 right now).
Jimbo
