Out with the old (carnage), In with the new.
Old Aug 7, 2008 | 08:55 AM
  #121
MaximusPrime's Avatar
Awesome thread. Can't wait to see track times. *Subscribed*
One question - I've heard that solid roller cams can make more power than hydraulic cams, however solid rollers require more maintenance? Is there any truth to that or is that just a silly rumor?
Old Aug 7, 2008 | 11:01 AM
  #122
Haans249's Avatar
That is completely TRUE.
Solid roller setups require that you recheck your pre-load every so often, and can be a pain in the ***. They do make more power then hydraulic setups because you actually attain full lifts and durations with the solid rollers, and you can run much more aggressive profiles in the cam with solid rollers because of the valvetrain required to run such a setup.
Hydraulic is more daily driver friendly, and more "soft" on valvetrain, thus you don't need intense valvetrain setups. You also can't run extremely aggressive lobes because you will get valve float because of the hydraulic nature of the lifters.
Old Aug 7, 2008 | 12:48 PM
  #123
aNuBiS's Avatar
Originally Posted by DansRedz28
Sweet! I would of ran some ported ls7 or l92 heads saved some $ and made same or more power.
Ya, and have a look in the dyno section. Could of maybe made similar peak power, but would of never carried it for such a long time. The curve is awesome with this setup.
Old Aug 7, 2008 | 12:57 PM
  #124
Haans249's Avatar
Saved money?! LOL, have you seen how much it costs to setup those heads for a solid roller application, let alone how much ported LS7 heads setup for solid roller costs? Keep dreaming cause it wouldn't have cost ANYWHERE near the same lol.
Old Aug 17, 2009 | 11:16 PM
  #125
Monte4ever's Avatar
Have you been to the track yet?
Old Aug 18, 2009 | 01:28 AM
  #126
grandsport1963's Avatar
don't listen to that clown SICLSX he thinks he knows everything! he is always trying to put in he 2 cents
Old Aug 18, 2009 | 05:28 PM
  #127
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Thread from the dead. I would be interested to see some results out of it.
