Out with the old (carnage), In with the new.
I have a ton of pics and will post them soon! Things are falling in to place fast!
Now here is the story of the motor going in. First off I will mention that during the install process of my valvetrain I had a bit of fun...
First, I set the Cometic headgaskets down and heads on top. I then lubed up the ARP studs and fastened them in and proceeded to torque them as described in the instructions.
Once that was done I drop in the pushrods, put on the shaft pedestals, and then start turning over the engine to install the rocker shafts on the pedestals one cylinder at a time. Well I guess I got ahead of myself and got distracted and managed to break one of the rocker shafts. So I called Crane and they were kind enough to send me a new shaft which should be here in a couple days. Then I notice that I cant even place one of the shafts on the pedestals because one of the pushrods doesnt wanna move no matter now many times I turn the motor over. Unbelievable. I ended up having to unbolt the one head and remove everything I installed and have a look and see. Turns out for some reasone one of the solid lifters didnt wanna go fully down its bore. I pulled it out and slowly started to work it in and out of its bore til it was comfortable in there and would move on its own. At this point I am a little worried and upset over the head removal already. I did however call Cometic and ask them if I needed to replace this headgasket. I was asked if the engine had ran, I mentioned that it was sitting in my living room, haha. He said aslong as it hasnt had any heat cycles and compression on it I was fine and could rebolt the head back on no problems. *phew* Soooo in the meantime I reassembled that head and valvetrain and proceeded to drop the engine into the car and bolt everything else up to it.
The pictures I have are just of the motor already bolted up and engine accessories being bolted to it. However my buddys gf has pictures of us lifting it into the engine bay and trying to shoehorn the thing in. Aswell as she tells me a video of us driving it across the floor in the house on its stand in order to get it back outside..lol
Engine in the car and crank pulley almost all the way on. I did make sure to have the pulley thru the cover before I bolted the cover down.
Heres a closer view of the above (notice the shaft and two rockers missing..)
Valley cover on with the stainless buttonhead bolts I picked up.
Intake and TB on with stainless hardware I replaced the originals with aswell.
Now with waterpump and power steering. (gf's Camaro in the background)
Closer look and alternator on now too.
Me hookin up the booster hose.
A/C, rad, MAF etc all on.
Closer look.
Started to get dark out! Lid/filter on, valvecover spacers on, and painted valvecovers attempted to be put on but....
Passenger side needs to be modified because the baffles hit the new valvetrain. Always somethin', so I'll be cutting those out this weekend I guess.
So all thats left at this point, is the headers need to be fastened to the heads. I got some arp header studs Im gonna try for that, and just got some new GM MLS manifold gaskets. (other than the one rocker shaft I have to replace and install asap.
Then I'll slap the plugs in, TR6's for now. Hoping my plug wires still reach them from the coil packs after the valvecover spacers! (I'll test fit that this weekend too so that way if I do need longer wires I can grab them first thing monday morning. So ya then the coil pack brackets and wires need to be put on and I still have to put the SVO green tops into the new fuel rail and install the fuel rail. Still gotta adjust the IFR table for these injectors too.
From there I will put the VR1 oil in for break in, and dexcool and try to see if this thing will fire! Wish me luck!
Did you remember to swap the outside leads on the cam sensor extension harness? We checked mine, and sure as **** they were ***-backwards where it plugs in to the plug at the old cam sensor location next to the oil sender. Good luck getting it fired up,,,,,,,,you're gonna love it!
Jimbo
Jimbo
Did you keep an eye on how long it took for you to build oil pressure?
I removed the fuel pump fuse right before fire-up and cranked the motor for a minute or so before we tried starting it so the oil pressure would come up quickly. Put the fuse back in and it fired right up,,,,took a while to find its idle, but no problems since. Oil pressure started coming up just a few seconds after the engine started. 50 psi cold idle, 38-40 psi after the oil temp reached 200. (Melling ported pump) Dumped the oil and filter yesterday (200 miles) and am gonna do 500 miles this weekend and change it again when I get back.
The torque difference from this motor compared to the 346 is amazing!
SOTP feel is VERY different, sound is alot deeper,,the 70 ci difference is awesome!.
Jimbo
Jimbo
OMG nice, hahah. I cant wait. I think I may do the same fuse thing aswell. ****** thing is filthy tho! jk hahaha. I havent washed mine in over a year myself!! Since I drove it last.
I'll try to take a vid of mine next week aswell on first startup.
I called Matt up at Texas Speed and he so graciously helped me out finding some info on what needs to be done to make them fit. I also added 3 washers beside them because they are loose inside the half of the mount that is bolted to the frame. I should of taken pictures but at the time it was the last thing on my mind, I was just trying to figure out how I was going to get this engine that is hoisted over my engine bay into the car ASAP.
Thanks again Matt!
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
All I had to do was adjust the throttle blade a bit and it will stay running around 1100rpm
I may have a video of first start up on my buddy's gf's cellphone and will try and post it when I get a chance.
May also take a video of it in action tomorrow
