Out with the old (carnage), In with the new.
http://www.por15.com/
The only things that wouldnt reach would be the new cam sensor, and the knock sensors that are relocated to the sides of the block. However, TSP provides you with a extension harness for these items. Stock PCM is good to go.
Yes, thats the one thing I havent upgraded yet and may hurt me at the track/dyno. I am still running pacesetter 1 3/4" headers with an ORY & electric cutout.
Im not overly worried about it tho, cause being that I didnt skimp out anywhere on the motor, I can upgrade the exhaust anytime. So Im satisfied with how I did things.
Also since I couldnt find a decently priced engine lifting plate anywhere that isnt backordered until eternity, I gave my buddy the valley cover plate off my old LS1 and he custom built me a lifting plate with 3 different lifting locations from center front and back. I tried it out and a couple holes were just off a tiny bit so I cleaned them up with a die grinder and now it bolts on excellent.
I also installed the oil pan pickup tube, and clayed the bottom of the pan and put it on with the new gasket. Mic'd the clay after and I got just over 6mm of clearance. Which works out to about a quarter of an inch. Which from what I am told, is just at the lower end of the scale as far as safe allowable clearance is concerned. I wasnt too enthused about that, but I did put three washers on the ARP main studs so that the windage tray would clear the ARP rod blots. I even had to grind at the hole on the pickup tube bracket for it to get back onto the main stud, and then held it there with the supplied nut.
My heads and cam/valvetrain should be arriving shortly and I will be ready to drop the shortblock into the engine, wire everything up, and then complete the upper half of the engine install. Then fire this thing up and see how she sounds! Give or take 2-3 weeks I guess.
I also yesterday installed a set of polyeurathane motor mounts. I was going to go with solid mounts, but I plan on getting a complete k-member next season with solid motor mounts built in so no use in buying them twice. The poly inserts were a quick and cheap alternative, my rubber mounts were shot!
Only thing I dont like about the mounts is the fact that apparently the one side of the mount is to be held closed with a tie wrap? I dont like this idea and will be isntalling a couple short bolts in the leftover holes with some loc-tite.
I'll take pictures of them completed shortly and post them up so you can see what I mean, I will then paint them I think with some POR-15 quickly just until next year.
Pics soon!
Ya, the stock rubber was pretty pooched! lol
Not a bad job on a ghetto plate if I do say so myself, bolts up nicely.
The Play-Doh I used to clay the pickup in relation to the bottom of the pan, lol.
I have since painted the mounts with some POR-15 and I found some nice short bolt and nut combo I will loctite on the clamshell to keep it fastened.
Plus heads & valvetrain etc have been shipped. They look like they will arrive any day now!
I did have my trans rebuilt a couple years ago with supposedly some of the best and strongest parts available. (heres hoping it holds)
Well after I drilled out the rivets on my mounts, there was nothing to hold them back together and the kit came with zip ties.
No, I didnt make it to the North Bay drags, but Earlton is where I plan on being this year. Really looking forward to it, and looking forward to maybe seeing you there in a new car?!
Got the rear cover on aswell and put in a new rear main seal (Federal Mogul) After reading some horror stories online of new design main seals and deciding wether or not to bother putting a new one in. However Matt@TSP said its still better than the stocker and to do it while its out. So its torqued down with the new seal. Also torqued the flywheel onto the rear of the crankshaft.
I put my old camshaft in the shortblock and bolted up my new dual timing chain to it and mock fit the new timing cover just so everything would be flush(pan/rear cover/front cover) upon getting the new cam. I will just have to remove the cover and undo the chain and throw in the new cam once it arrives shortly. Otherwise the shortblock is now done.
UPDATE:
Also just got my AFR225 heads in today, along with the Crane shaft mount rocker system, solid roller lifters and 8" pushrods. Just missing the cam now and I will be ready to complete the long block.
I'll have pics of the new parts and updated work completed, hopefully this evening. Things are looking good.
I borrowed a brand new stock converter from a buddy who runs a shop and it goes onto the trans almost instantly.
So I guess I have to contact Yank on Monday and see if I can get it looked at and hopefully doesnt take too long
As fas a the conveter, as soon as I saw the engine on the hoist with the converter still attached to the engine, I was like "oh boy"! I'm supprised that the engine was easy to come out with it still attached! Good thing is that the input shaft on the tranny is still go, converter man can cut it open and fix converter.
Any transmission OR engine that I've ever taken out the with converter attached has always been a pain in the rear to work with. Most of those was because I came in after someone else and got those awesome bolts that was ROUNDED off at the head, and had a ball getting those out!
btw......Love the build, I know the pocket book is feeling it!
David
put the damper on before you tighten the front cover bolts, and also tighten the front cover bolts before you tighten the front oil pan bolts.
if you dont let the damper allign the front cover it will f the seal and leak.
