Will ARP Thread sealer be ok to used on the Rocker arm bolts ?
i Have Patriot Stg 3 Heads and the intake ports are drilled all the way through for the rocker arm bolt to come through ? Is is Proper to use ARP thread Sealer on the Rocker arm bolts ??
Should i used lock tite too ? or just the ARP Thread Sealer ? Im using Stock Rocker Arms From the LS2 and the Stock Rocker Arm Bolts ..
Arp
i used ARP White gritty thread sealer on the intake and Exhaust rocker bolts ,
since i used it on both intake and exhaust rocker bolts , they should hold good enough right ? I shouldnt need blue locktite should i ?
