Trick Flow 235/245 vs LS7 heads on 427?
I know it's not a 427 but I've got a 408 with TFS 225's and they made the numbers in my sig with a mid sized cam 24x/25x and peak lift is .613. If I ever decide to build a bigger motor I'll be putting TFS on those too.
I don't understand how the TFS heads can ever make more power than the better flowing LS7's, everything else being equal. What am I not seeing here?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Question:
the Trick Flow heads state
235cc runners
Intake Valve Diameter (in): 2.080 in.
Exhaust Valve Diameter (in): 1.600 in.
the LS7 heads state
283cc runners
Intake Valve Diameter (in): 2.200 in.
Exhaust Valve Diameter (in): 1.610 in.
The Trick Flow heads are just another remake of the "old" 5.7L heads right (still small valves in original locations)? On a big (4.125" +) bore engine, why would anyone waste their time not going with the LS7 (honest question, no sarcasm here)?
235cc runners
the LS7 heads state
283cc runners
Question:
235cc runners
the LS7 heads state
283cc runners
235cc runners
the LS7 heads state
283cc runners
Everything else is not equal.
All I am saying here is that the manifolds are different as well as other things. Not saying one is better than the other, just saying that they are different.
Not trying to get into a which head is better discussion.
Flow numbers are not everything, neither is velocity.
With more "normal" constraints of candy-cane plastic intake, off-the-shelf headers, streetable low-RPM manners, and desire for strong midrange as well as top-end, it's much less clear which design will yield optimum results, since both designs can flow enough to support a 6500 RPM peak. All you can say for sure at this point is that people have gotten great real-world results with both designs.
BTW, if you change one of your assumptions - displacement - the equation would be different. On a max-effort street 481, I'd think the LS7 heads would have a clear edge.
Well, it depends on what you mean by "properly matched". A number of vendors are claiming around 400 CFM intake flow for their ported LS7 heads. That's enough flow to support over 800 flywheel HP. To make 800+ flywheel HP from a 427, you'd have to spin it to around 8000 RPM. This would require the rest of the combination - particularly the intake and headers - to be designed to tune for optimum efficiency at higher RPMs than any off-the-shelf pieces out there. And the resulting motor would not meet most people's definition of "streetable".
Basically, two engines, 427ci each, same compression, both using the LS7 intake and one has the Trick Flow 235 heads and the other with the LS7 heads, both with max porting jobs. Then choose the best cam for each to best suit each head, remain pump gas, streetable and going for the most power.
Which engine will make more power? Keeping the cams out of the 260's.
Well, not talking about that type of engine which would require huge compression, race gas and definitely a sheet metal intake as well as some very expensive high-revving head components. I'm talking about a max effort, pump gas (91 or 93 octane) using the LS7 or Fast intake and a cam that is aggressive but will not cause stalling at a street light. Most people are going for around 600 RWHP and still be streetable and reliable.
My car fit the bill above. it would pull 1300 rpm in 6th and it had no problems idling. It made 548 rwhp with a hurt cylnder. I will have better results when I can get it back together..
#32
I'd also say that once you decide to restrict yourself to a plastic intake, the intake design is at least as big a factor as the head and probably more so.
#33
I'd say there isn't enough real-world data to conclude definitively one way or the other. The dyno data we're seeing on the 'net might suggest that the LS7 combos might make a little better peak power, while the cathedral port heads/intakes give a little more area under the curve, but you have to take into account that all of the data is created by interested parties, who do not necessarily have the expertise or incentive to optimize both combos and compare.
I would have to agree with you. Because the intake is bolted to the head and the engine doesn't know where one starts and the other ends. Most people seem to not remember this.
#35
The TFS heads heads are not on the same valve angle or the same spark plug location as a standard LS head.
__________________
http://www.trickflow.com/emain.asp
Click Above for Product Information
#36
Click this link to my website to see and hear the Trickflow Heads on a LSX454 running thru closed exhaust (Dual Magnaflows w/X-Pipe).
Go to the 2 videos.
http://www.fquick.com/tcr98taws6
Go to the 2 videos.
#39
Go to the 2 videos.
Go to the 2 videos.
Questions for you: What cam are you running? What compression (are the TFS 235's milled)? LME shortblock I presume?
#40
He had our cam but changed it due to bucking issues under 3k rpm. Before it made 624 rwhp.
not sure on the cam size now but its still right at 600rwhp moth better drivability.
