LS7 Cam selection - Looking for the new info!
Specs on the motor follows:
Built by Dave Diluca of Canadian Performance
-4.125 bore LS2 block resleeved with Darton LS7 sleeves
-Diamond LS1 4.125 pistons (only shelf pistons they had at 4.125 bore at the time)
-Callies 4" Crank
-Callies Compstar 6.125 rods w/ARP 2000 rod bolts
-Morel Hyd Roller Lifters
-SLP high-flow oil pump
-JRP Double Roller LS2 timing chain
-LS7 heads/intake stock form.
-Stock LS7 rocker arms w/ Harland Sharp Mod
-PSILS1511 Beehive springs with Katech Retainers good to .700" lift:
the springs in this setup are outstanding, and have been holding up to my extreme cam with no problems, the retainers are TOP NOTCH.
-Compression right at 11.38:1
My custom spec'ed cam is the following:
-242/256 .646/.668 113+3 LSA
lift is with the LS7 1.8 ratio rockers, and they are comp lobes, exhaust lobe is not a catalog lobe.
This motor has just been a complete blast since start-up, and has run very well. I dyno'ed it after putting a soft tune in her and on a Mustang Dyno it hit 500 rwhp 440 rwtq. The dyno I used it know for LOW numbers (a high compression ETP canted valve headed race 427 dynoed near similar numbers) so i was quite happy with it. Same dyno the Katech LS7 Camaro was run on that made the 540 hp. I'm still running a single exhaust system back to a flowmaster 80 series...which interestingly is also only good to 500 hp. So, I think its doing well. I have since upgraded to ARH 1 7/8 headers from my edelbrock 1 3/4 headers.
As far as the cam goes, with the greater vast amounts of information now available, how does it look? Do the valve events coincide with what is now known to be working well? I left for Iraq 2 weeks after I put the motor in and dynoed back in August 2006, so just looking for some critiques on the cam with lessons that have been learned.
Best,
Adrian
Your cam is pretty typical of the latter philosophy, and you wouldn't likely get a great deal more peak HP with a new cam because the tuning frequency of the LS7 intake works against you heavily over 6500 RPM, and your cam is already pushing the torque curve as far up the range as that intake will let it.
Some pretty good advice. Bigger is not always better with those heads. You will definately gain mid-high range with the torquer .220/.244 by swapping that intake with a 4brl accufab 1200+cfm with a plate. (Not for everyone due to fitment issues). Im gonna engine dyno that exact setup in a few weeks and will post up the results. Trending Topics
I agree, I think maybe my cam is just a little much, but I think its making pretty good power, the torque curve is about as flat as can be, which is great. I need to get that new exhaust installed and re-dyno after all the changes and see again where I'm at!
Your combo is close to optimal for a max combo already. If you're hungry for more, I'd work first on the exhaust. You could probably get away with another .4 to .5 point compression with the late IVC on that cam, and the right head porting might net you another 15-20.
Best,
Adrian
Best!
Adrian
PS, your throttlebody cable bracket that you made for me is still tick'in and working well
You know how it is?
