Is there an easy way to check PtV clearance?
I have the heads off. The pistons are dished 28cc w valve reliefs and the cam is 246/250 .632/.635 on a 112+4. I don't want to have to install the heads twice doing the claying the piston method unless I have to. Anyone know a better way?
the clay is the easy way as far as I know... should just be a able to throw a few head bolts in and pushrods for one cylinder.. you should just be able to do one cylinder i cant see it taking that much time...
