Ls2 single chain 427& up?
Old Jun 22, 2008 | 05:43 PM
n20stroker's Avatar
Default Ls2 single chain 427& up?
Just want to see if anyone is runnin a ls2 single timing chain on there 427 & up LSX motors and not breaking them. I have a friend with a 408 that snapped a ls2 chain.
Old Jun 23, 2008 | 07:08 AM
Max@Cartek's Avatar
If you can run a double roller then I would.
Old Jun 23, 2008 | 07:45 AM
venom ws7's Avatar
Double for sure.
Old Jun 23, 2008 | 07:51 AM
aNuBiS's Avatar
I did some research on the matter, lots of people saying single can handle 1000hp, etc etc. That being said, Im running dual
Old Jun 23, 2008 | 07:59 AM
Max@Cartek's Avatar
A lot of it depends on the cam profile.
Old Jun 23, 2008 | 05:21 PM
n20stroker's Avatar
custom cam 254/272 113+5 660/687 lift
Old Jun 23, 2008 | 05:37 PM
03 BUSA's Avatar
I am running single.
Old Jun 23, 2008 | 07:04 PM
Max@Cartek's Avatar
Good luck with the single roller, but I would swap it out with a double roller.
Old Jun 23, 2008 | 07:10 PM
JL ws-6's Avatar
Race your car!
That's a big cam, if I were to go to something that big, it would #1 be a solid roller, #2 I would definately run a double chain.
I have a single ls2 chain on my car right now, but over the winter I want to make a few changes in the motor while I have it apart. One of them that is on the list, is a double chain for the piece of mind.
Old Jun 23, 2008 | 08:27 PM
67SS509's Avatar
10 Second Truck Club
I have always run the Cloyes single chain who is the manufacture of the GM LS2 chain. I have run it hard and past 7k many times with no problems. Never even had one to stretch yet. Engine specs are in my sig.
Old Jun 23, 2008 | 08:49 PM
JVetthead's Avatar
Just broke a LS2 chain... after maybe 5 track days...
I'll never use one again
Old Jun 23, 2008 | 10:26 PM
Spinmonster's Avatar
What is involved with getting a double roller to work on an LS2?
Old Jun 24, 2008 | 05:32 AM
n20stroker's Avatar
Well i found a single Iwis chain from SDPC that is rated at 1000hp and is an upgrade to the ls2 chain. Has anyone tried this chain.
Old Jun 24, 2008 | 06:17 AM
aNuBiS's Avatar
I would run a dual
Old Jun 24, 2008 | 11:52 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
It all depends on the application and the cam profile. We do have the Iwis chain for $42 as a great upgrade from the LS2 if you want to run a very strong single. We recommend upgrading to it rather than the LS2!
A double is never bad insurance
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Jun 24, 2008 | 12:03 PM
vettenuts's Avatar
Any word from Cloyes on their single hex-adjust with the Torrington bearing?
Old Jun 26, 2008 | 03:14 PM
Nope, not yet.
__________________
Old Jun 28, 2008 | 11:38 AM
the big kahuna's Avatar
how strong are the cloyes signal chains i am running one and reason is i have the mellings oil pump and the double would not fit right cam is a 240/244 now IM hearing they break oh boy
Old Jun 28, 2008 | 12:01 PM
vettenuts's Avatar
Originally Posted by Scoggin Dickey
Nope, not yet.
Spoke to Mike at Cloyes on Thursday. The new Torrington bearings they received had a 0.030" larger ID and were sloppy on the cam gears that had already been machined, so they had to scrap all of the cam gears and start over. The engineer working it is on vacation, but Mike was estimating around 3 more weeks. Guess its good I put off my installation until next winter.
Old Jun 28, 2008 | 01:06 PM
n20stroker's Avatar
why wouldnt the double fit right? I just ordered one from a sponser and they said it would fit with a meiling oil pump
