510cid small block
Old Jun 25, 2008 | 08:09 PM
needadvice's Avatar
Originally Posted by Domexitium
Jesus, i didn't think it would be that expensive!
It's not that expensive.
454ci: cam in the low 240's, .630 lift, 12:1 cr
$2,800 LSX iron block, ARP studs with a 4.185 bore
$3,500 Forged crank (4.125), rods, pistons
$3,000 Complete hand ported LS7 heads that flow (~400@.650 lift...270+ exh)
$4,000 Sheet metal intake, 105mm TB
$1,000 Gaskets and misc stuff
$500 SD tune
If you want a BS3 computer go for it, but not necassary.
Close to, if not 700 RWHP (M6) right there. Add a direct port 300 shot for a 1,000 RWHP killer.
C6 Z06's are doing 620 RWHP with 240 sized cams with around .630 lift. BUT...with the cheezy "by comparison" LS7 intake. With 27 more cubes than the 427 Z06 engine, a cam matched to the sheet metal intake and 12:1 cr....700 RWHP on pump gas should be easy (M6).
Old Jun 25, 2008 | 08:24 PM
99blancoSS's Avatar
$500 SD tune
You werent paying attention..LOL
supporting a 4.5" stroke even on is going to leave next to nothing for a ringland,
300 shot isnt a good idea
My short block is $6234.. balanced, blue printed ready for your heads.
Old Jun 25, 2008 | 08:44 PM
84ls1_transam's Avatar
High Performance Pontiacs say...
What is needed is a block that can be safely bored to 4.250 without getting major cylinder wall deflection, and it must have a rigid, thick deck with extra head bolts to hold the cylinder pressures required to reach over 2,000 hp. The real dream is to be able to do this at an affordable price. GM Performance Parts has now stepped up to the plate with a big bat, but will it be a home run?
L92 heads would work fine for this, and I have heard of people using the LS7 or F.A.S.T. intake. The stroke on the other hand, I would be worried about. I would think if someone is promoting there product saying it can be built up to 510 CI, I would say it's possible.
Old Jun 25, 2008 | 08:47 PM
Domexitium's Avatar
Originally Posted by 99blancoSS
We dont go bigger than a 4.185 with our LXS 454 and we dont recommned n2o with it either. We like the 434 for boost and nitrous use.
why don't you recommend n2o on a 454?
Old Jun 25, 2008 | 08:53 PM
slingshot928's Avatar
he doesnt recommend it because there is not enough material left in the block to hold it together safely, also with it bored out all the way you cant rebuild it, you need a new block if it blows up.
Old Jun 25, 2008 | 08:55 PM
needadvice's Avatar
Steve Dimirjian (Race Engine Development) says a 250 shot is no problem with a 4.185 bore, and thats with a resleeved LS2, the LSX iron block is stronger. 300 is not that much more than 250.
Old Jun 25, 2008 | 08:57 PM
needadvice's Avatar
I was explaining that 650-700 RWHP isn't as expensive as most think it is. It doesn't take $30,000. The OP mentioned 700+ RWHP N/A on pump gas.
Old Jun 25, 2008 | 09:00 PM
needadvice's Avatar
Yo ucan spray a 454, no problem with a 250-300 shot, as long as it doesn;t detonate.
Old Jun 25, 2008 | 09:07 PM
Domexitium's Avatar
Well, thats what i figured.. I would like to have a 1000rwhp n2o monster!
Old Jun 25, 2008 | 10:11 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
has anyone even broke the 700whp mark??????? much less 750??????
a 454 is a long way from a 500+ci
Just because the material might be sttong enough to hold the power the rest of the components might not, with increased cylinder pressure you need increased clamping force and strength. You will not have enough gasket between the cylinders to keep it together.
Have you ever priced out what it takes to make a NA motor or even a nitrous motor live at 1000hp? How often bearings, rings and pistons need to be replaced?
Do you know how far up the piston the pin will be pushed with a 4.125 stroke and how little of a ringland you will have? All you will have is a ticking timebomb that will grenade itself.
it's not as simple or cheap as you think, just ask anyone who has tried. if it was everyone would have a 8 second car.
Old Jun 25, 2008 | 11:56 PM
BigBronco's Avatar
Guys, it is all relative. 720 hp on the Engine dyno with a 500" LS2 block with sleeves/deck plates from ERL.
250/255 @ .050" Hydraulic roller. Cleaned up LS7 heads AND LS7 Intake.
93 Octane too.
Old Jun 26, 2008 | 12:10 AM
  #32
Caveman's Avatar
10 & 11 Second Club
93 Octane too.
That would be a nice sleeper car !
Old Jun 26, 2008 | 12:13 AM
  #33
BigBronco's Avatar
It idles fairly well and was tuned on a GM factory ECU.
Definitely a lot of room to make this motor WAY more serious than where it is at.
With that long stroke, piston speed would seem to be worrisome but turning the motor up to 6500 rpm resulted with no issues at all. Even hitting it with the N20 showed no signs of problems. After numerous pulls I might add.
It is in the Black Z28 and has good road manners even though it has a 3 speed in the car. Definitely is a runner.
Old Jun 26, 2008 | 01:01 AM
  #34
99blancoSS's Avatar
Thats because you can use a longer sleeve when you re-sleeve we did it with mine 4.250 stroke ls2, its not the same as the LSX block, its not apples to apples
And again its not the bore it's the stroke
Old Jun 26, 2008 | 01:04 AM
  #35
99blancoSS's Avatar
Detonation without n2o can take out a piston on a hi compression motor.
I'll post some pictures of a 12:1 454 that detonated. chunks of piston missing, engine wasnt very old at all
Old Jun 26, 2008 | 01:21 AM
  #36
racer7088's Avatar
Arrow
The bore isn't what people are worried about. It's the CH of the piston and what rings you can get in there and how far down you can run them. You need some top and second ring land to run really big NOS reliably. You could run a 500 shot easy on Steve's blocks with the right crank rods and pistons all day long. The pistons are what will go first not the block.
Old Jun 26, 2008 | 05:02 PM
  #37
needadvice's Avatar
I'm only talking 4.125 stroke in a GM LSX iron block, thats not too long for a big shot.
Steves resleeved LS2 block with the longer 5.800" sleeves is good if he wants to go longer stroke to get closer to 500ci. Its also fine to spray a 250 shot with a 4.185 bore with the resleeved LS2.
Old Jun 26, 2008 | 06:22 PM
  #38
99blancoSS's Avatar
only 125/1000's .... lol, ok. Read the post above yours.
No one is saying size of the bore is the problem.
Old Jun 26, 2008 | 06:26 PM
  #39
ALLBOTTLE's Avatar
LS1TECH Sponsor
it's pointless if he doesn't understand now he never will, afterall look at all the guy in the nitrous section running 300hits, it must be so common no one even talks about it anymore.
Old Jun 26, 2008 | 07:02 PM
  #40
needadvice's Avatar
Look, I understand. Anyone that goes to the max bore on anything is a moron anyway, for more than one reason, thats why talking about going 500+ci is just stupid. A 4.185 bore on either block is fine for a nice shot of spray. A stroke of 4.125 is just fine for both as well, resleeved LS2 and the LSX block, for any kind of purpose.
Another blah, blah, blah thread I guess.
