510cid small block
Old Jun 26, 2008 | 07:30 PM
  #41
LSGunZ28's Avatar
Are they ever going to make a large bored aluminum LSx engine? whats the biggest LSx(smallblock) bored engine (safely and not running FI)
Old Jun 26, 2008 | 11:47 PM
  #42
Domexitium's Avatar
Big Bronco, Do you care to elaborate on your build?
I should say would you please elaborate, it sounds like a work of art!
Old Jun 27, 2008 | 10:58 AM
  #43
racer7088's Avatar
Arrow
4.200 is the biggest I have seen personally but you could run 4.250 if the metal is there but it's really pushing everything. Some normal SBC deals are like that and they have the same bore spacing.
Old Jun 27, 2008 | 12:05 PM
  #44
JS's Avatar
JS
Phil what record do u hold?
RobZ has the record for NA H/C at 10.33?
Old Jun 27, 2008 | 12:16 PM
  #45
Paint_It_Black's Avatar
Sorry but the record for H/C is not 10.33
10.33 won't even beat the cam only record.
Pretty sure there was a stock internal car running around a 10.3
https://ls1tech.com/forums/drag-racing-results/818893-all-time-fastest-n-stock-ci-h-c.html
Old Jun 27, 2008 | 12:20 PM
  #46
JS's Avatar
JS
For a C5 the H/C NA Record is 10.33 for a 346CI engine.
Go check the corvette forum
Old Jun 27, 2008 | 01:25 PM
  #47
Ooohh.. corvette.. nvm I was thinking in general!
Old Jun 27, 2008 | 02:59 PM
  #48
Quick Carl's Avatar
Here is one of the threads on the build.
https://ls1tech.com/forums/generation-iv-internal-engine/457847-sam-s-500-ls2-project-progress-pics.html
Old Jun 27, 2008 | 03:24 PM
  #49
odarabla's Avatar
Originally Posted by .ALEX.
all it would do is fizzle, supporting a 4.5" stroke even on a talldeck block is going to leave next to nothing for a ringland, and 4.250 bore would mean almost no material left on the sleeve, i dont see the motor living very long between rebuilds and at 4.250 bore you would need a new block every time.
He is talking about an LSX block. You can build a 540ci+ small block from that block, but everyone is right. Finding a small block ls1 head to match the cubes is going to be very pricey!! I'm not even sure the make a head that could flow enough cfm for that build. He wouldn't have to get custom headers and intake built but the heads would be the main concern..
Old Jun 27, 2008 | 08:07 PM
  #50
ALLBOTTLE's Avatar
LS1TECH Sponsor
540?!?!?!?!?
put down the crack pipe, even the tall deck when it comes out wont make a 540.
Sure dart may be able to make you a custom super tall deck block but 540 is ridiculous.
Old Jun 28, 2008 | 02:11 AM
  #51
odarabla's Avatar
540?!?!?!?!?
Someone needs to do his homework before coming on this site acting like an *** clown!! You try to sound like a smart boy figure out the math. The website says 500+ ci but figure out what the max is! Next time try not to be such a dick!!!
http://www.crateenginedepot.com/stor...FQEnGgodVjl7uQ
http://www.gmperformanceparts.com/En...6454&engCat=ls
Old Jun 28, 2008 | 02:48 AM
  #52
drz's Avatar
drz
Uhm, by my calculator, the advertised maximum dimensions of the LSX block (4.25 bore x 4.50 stroke) yields 510.71ci, not 540. . . .
For that matter, good luck putting a crank longer than 4.125" in the standard-deck LSX block anyways, which by the way has the same ~5.5" cylinder length as the 6L and LS1,2,3 blocks. A 4.25 stroke CAN be done, but the builder and piston engineer have to REALLY know what they're doing. I don't know where GM came up with the 4.5" number, that'd require a piston with something like a 0.5" or shorter CH, which is physically impossible.
Now if you sleeve a block with a ERL deck plate, then yeah, 4.5" stroke no prob. . . .
Old Jun 28, 2008 | 04:44 AM
  #53
odarabla's Avatar
We are not talking about the standard deck!! I was talking about the 9.70 deck that is offered as a tall deck in the LSX block. I may have been a little off with my math but the point of it all was you can build a 500+ci small block out of a LSX block.
Old Jun 28, 2008 | 08:58 AM
  #54
racer7088's Avatar
Thumbs up
Yep it might be possible with the taller deck block just not the normal deck block as DrZ says. There just not enough cylinder for that stroke on the shorter deck engine.
Old Jun 28, 2008 | 01:33 PM
  #55
odarabla's Avatar
Agreed!
Old Jun 28, 2008 | 09:11 PM
  #56
drz's Avatar
drz
Has the tall deck LSX even been released yet? If not, why are we discussing it in the present tense, ie "you can build a 540ci+ small block from that block"??? With the current GM offering (standard deck only), the biggest practical LSX you can build is still around 460-470 ci, so it's misleading to suggest a 500+ci LSX can be built today since the tall deck version isn't in the hands of builders yet. . . .
EDIT: Some searching revealed the tall deck version was SUPPOSED to be released this month or last, but I haven't heard anything more about it, nor seen anyone who claims to have one in their hands yet. . . .
Old Jun 28, 2008 | 11:21 PM
  #57
LSGunZ28's Avatar
I see... what if they used graphite cast iron sleeves?
Old Jun 29, 2008 | 01:42 AM
  #58
racer7088's Avatar
What I was saying is that on regular 4.400 bore spacing blocks they have already succesfully run 4.250 bores so if you had the right LSX block you could probably do that on an NA only engine if you wanted to push it all you could.
Old Jun 30, 2008 | 12:01 AM
  #59
BigBronco's Avatar
I can go into more detail tomorrow. I just got back into town.
https://ls1tech.com/forums/sponsor-vehicle-projects-shop-tours/621016-sam-erl-wiseco-pistons-500-ls2-buildup.html
There is a link to the build up and basic spec info. (Even dyno sheets overlaying nitrous and N/A pulls)
The pistons had a pretty tall compression height on them by the way as that motor had plans on getting sprayed at the track, etc. Even with the 4.500" stroke, it turned upwards of 6,600 rpm with no problems whatsoever. Ring's sealed up, cylinders looked/stayed strong with multiple 900+ horsepower pulls.
With the newer tall deck LSX option, it certainly holds a bright future for NICE pump gas N/A builds for people who would like to go that route.
Old Jun 30, 2008 | 09:23 PM
  #60
needadvice's Avatar
https://ls1tech.com/forums/showthread.php?t=621016
what was the difference in HP with the LS7 intake and the Beck intake....on motor?
