Solid Roller rocker arm choices?
Old Jun 26, 2008 | 06:27 PM
n20stroker's Avatar
Default Solid Roller rocker arm choices?
Just wanted to see what some of u guys are runnin with your solid roller setups.
Old Jun 26, 2008 | 06:29 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
you can go T&D, Comp, Crane, or Jessel..... How deep is your wallet?
Old Jun 26, 2008 | 09:45 PM
n20stroker's Avatar
Think Im going to give Thunder a call and see if they have a set Of T&D in stock
Old Jun 27, 2008 | 07:20 AM
aNuBiS's Avatar
Crane's here.
Old Jun 28, 2008 | 02:35 AM
O6DODGE's Avatar
I have a set of T&D pros I am using on mine.
Old Jun 28, 2008 | 03:46 AM
Pwebbz28's Avatar
I did NOT have good resultls with my T&D rockers on my solid setup. Do i quick search and it should bring up some good reading on them. Erik @ HKE gave some insight as well.
Old Jun 28, 2008 | 05:58 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
^ You also have a new set. You can find random used sets of T&D rockers all over the internet for around $500.
Old Jun 29, 2008 | 08:05 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
they made changes the design to clear stock valve cover rails and it royally messed up the geometry
Old Jun 29, 2008 | 08:59 PM
John02SS's Avatar
I try to run Jesels on all the solid stuff. I even run them on my Hyd stuff just for piece of mind.
