L92 DOD and VVT elimination..Why?
Should I keep them functional? I'm only shooting for 500-ish hp.
Thank you.
VVT is usually dropped due to similar reasons. If you put a hot cam in with a VVT cam phaser then you could run into PVT issue's. Since the Cam phaser advances the cam in the low rpm and retards the cam in the upper rpm -vs- keeping the cam at a set point for valve events throughout the rpm range.
To be honest a performance VVT/AFM cam is needed because VVT allows for better hp and tq throughout the power band while AFM allows for better fuel economy while daily driving.
I've been an advocate of AFM/VVT performance cam's for a while, just no one listens...
I know that I saw a company out there that had a cam that allowed the use of the VVT I can't remember who it was though. The AFM is not a huge deal for me I guess.
Any major economy or power losses from getting rid of them? I like the idea of keeping this a little more simple.
Thanks
Thanks
To my knowledge, we are currently the only company that does VVT camshafts. We have setups that can make a stock L92 safely make up to 545HP. Unlike the factory setup, our cam timing table is set up to make peak power/torque all the way across the RPM range on our M-90 Control Systems. We don't run Active Fuel Managment (AFM) on our products.
There are major losses to be seen from removing the VVT system. The VVT greatly broadens the torque curve for a streetable, high output combination. The data in the link below shows some of the performance benefits of VVT on just a stock L92.
https://ls1tech.com/forums/showthrea...&highlight=vvt
Hope this helps!
-Geoff
It should work still work though. I would keep the VVT as well.
EDIT: also the fuel mileage gain from AFM is small and if you don't have the right set-up, gears tire size then it my not stay in V4 mode long if at all.
That's what I mean, though, there isn't a tuning option to even play with it now.
-Geoff
-Geoff
-Geoff
