good valvetrain combo?
https://ls1tech.com/forums/new-products-showcase/836028-yella-terra-ultralite-shaft-mount-rocker-arms-l92-heads.html
http://livernoismotorsports.com/product.phtml?p=1665
It's good that now someone is making rocker arms for the L92 heads. The Yella Terra parts look good.
Livernois uses those springs on their L92 heads with heavy stainless valves.
Providing all other components are comparable, I would not see why the springs and rocker arms would not work.
Just double check your current spring diameters to make sure there are no changes to the spring pocket diameter.
Oh, and maybe consider stronger retainers and keepers.
That is what I would do.
https://ls1tech.com/forums/showthread.php?t=836028
from looking around, these would seem to be the same size correct?
Or, go to Amazon.com and buy a digital vernier caliper for about $35.00 and start measuring.
Trust No One!
