need help peiceing together my own L-92 heads!
im buying everything from summitracing will all this fit, and is it everything i need? they are manley parts.
MAN-11620-8 Valves, Intake, NK-842 Stainless, 2.165 in. Diameter, .3133 in. Stem, 4.900 in. Overall Length, L-92, Set of 8
MAN-11621-8 Valves, Exhaust, XH-426 Stainless, 1.59 in. Diameter, .3136 in. Stem, 4.923 in. Overall Length, L-92, Set of 8
MAN-13098-16 Valve Locks, Machined, Steel, 7 Degree, 1-Groove Beadlock, 5/16 in. Valve Stem, Chevy, LS1, Set of 16
MAN-221436-16 Valve Spring, Dual, 1.290 in. Outside Diameter, 377 lbs./in. Rate, 1.100 in. Coil Bind Height, Set of 16
NAL-12582714 Cylinder Head, Bare, Aluminum, L92 Port, 70cc Combustion Chamber, Chevy, Small Block LS, Each
