LS7 injector size/L76 injector hole size???
I have the LS7 injectors on my L76 intake and I called Craig over at NX to see if the NXL kit will work on the L76 intake. He said I may have to modify the mounting brackets a bit but as long as the LS7 injector diameter was .550 I should be fine.
Does anyone happen to know the LS7 injector diameter? If not if you happen to have any specs on the L76 intake manifold handy could you check to see what the diameter is on the fuel injector hole?
I did a search for the injector and the injector hole sizes on google and after an hour or so I just gave up. Any help would be appreciated
