Whats holding it back, view power graph
The LS2 manifold is not the best but still shouldn't be causing your engine to sign off so early.
Sidenote: Do you have any pics of your Cerbera and any TVR Cerbera Speed 12 pics? I've looked all over good high res shots.
i have no cats.
Valve springs are Dual Extreme Gold.
The injectors are at 100% but the AFR is ok.
My Dyno operator thinks there is a restriction, in the fact that air flow is being restricted somewhere, it might be the exhaust manifolds even?
My friends 427 made 684bhp earlier in the day, and hung on until 6500rpm but peaked at 6000rpm, like i say it hung on making useful power till 6.5K. He is on the same bore as me but 4.125 crank. Bigger exhaust manifolds, that in all fairness look alot nicer flow wise because he has alot more room, they are also 1 7/8 mine 1 3/4, he has a fast manifold, and is on the off the shelf comp cam 238/240. He has some Very nice heads also, RHS?? that have bigger valves. Like i say i'm not necessarily chasing bigger numbers, just more rev range. Cheers.
My $.02
Just a wild guess
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
, however it was my 383 you did it for! also i opened the chambers out to match the 4.070 bore and cc'd the chambers from 62cc to 65cc to get the comp ratio i desired.
and if it works then youll atleast know that is part of why
the LS2 intakes seam to fall on a stock size LS2 , so anything bigger id think it would start falling off a little sooner even ported
What is your injector rated at?
Fuel Pump flow?
Are you running some style of block hugger exhaust?
Are the springs set to within .050 of coil bind as Patrick G mentioned?
Are you seeing a good sweep pattern on your valvestem tips?
Just for kicks at is max timing currently at?
A well designed 1 3/4 can carry an engine the size of yours beyond this RPM. Look at LG Pro Long Tubes on the myriad of Vettes with 400+in engines.
Your AFR is a little leaner than I would prefer. The graph appears to be in the 13:1+ range. I generally tune for 12.4-12.7:1 NA.
An injector @100% is always an issue. That means it's open constantly. Not ony this this detrimental to the injector it's possibly endangering your engine.
A hot tune + injectors on the ragged edge = an engine thats an atmospheric change away from meltdown.
I am Really limited on exhaust design, i'll post some pics later so you can see what i'm talking about. The valve springs are at stock height also. But i really dont think its a valve control issue, it revs on the road to past 6500 without hitting say, a brick wall just its not as convincing as i'm sure its potential could be.
I think the fast will help too. I gained a lot with the fast on my H/C 346 over the LS6.
