Looking to start Frankenstien
I'm getting ready to graduate college and start bringing in more money. Naturally most of it will go into my '01 WS6. I pretty much want to do a heart transplant. Basically pull the whole motor and start a new one from scratch. I want to know every piece of the engine and leave no doubt.
Before I'm told to start else where and the engine can wait, I am planning on starting with the suspension and drive train first. How ever in the mean time I want to be assembling the new engine on the side so when the rest of the car can handle it I can make the swap.
I want to start with an LS2 based bottom end but thats about as far as I have gotten. All I know is that there are a lot of similarities in the LS1 and LS2 but I'm not sure what they are. So while I'm looking for heads, cam, intake manifold, etc., I'm not sure what will be compatible as far as what is called a LS1 part but will work fine on a LS2 platform.
I guess my question is where can I find he shake down of what I can do and what is universal between the engines like a LS1 based top end on a LS2 bottom end. Also what I would have to do to the car itself to make the swap seamless. Like I said it's going into an '02 WS6.
Don't get me wrong, I know my fair share about engines and assembling them and have been around the block a few times as well, I just hate to say I'm not as familiar with the whole LS based family as I would like to be.
I also want every thing to be new!! I've had a lot of trouble with little stuff biting me in the *** and I want to just put it to bed!!!!
Thank you in advance for any input.
Search is your friend.
You need new:
Valley cover
Timing chain cover
Timing chain and gear
Timing chain dampener
Cam sensor and electrical connector
Tap block for LS1 knock sensors
Plug PCV outlets on rear of each valve cover(2)
Run PCV lines per LS6
LS2 head bolts
Is this correct/everything?
I want to know every little detail.
everything swaps over from your ls1 except what you mentioned. you dont need to tap for you knock sensors unless you are running some big headers. but it dosnt hurt to do it anyways.
read the stickies at the top of the subcategory that you post in. it has all the info you need on the swap. https://ls1tech.com/forums/generation-iii-internal-engine/659189-ls2-conversion-info-inside.html
I was thinking a cam with 229/242 .631/.631 114 lsa
My next issue would be what size primaries to use on the headers:
1 3/4
1 7/8
1 3/4 stepped to 1 7/8
that is a small cam for what you probly going to want horsepower wise.
go with a 1 3/4 stepped to 1 7/8 if you are going with that small of a cam. if you go bigger go with a 1-7/8 stepped to 2"
what kind of power range are you shooting for?
this cam should give you what you are looking for with heads also makes about 593rwhp. looking at dyno results on here.
VRX7 244/248 .612/.596 112/113/114 LSA. the closer the LSA the more top rpm's you will have. so the more rpm you can get without valve float the more power you should make, as long as that cam makes power that high.
so the more rpm's you can get your motor to spin the more power you will make.
I'm looking to spin it about 7 grand and that is way to much for a set of heads. If I don't get 600 I won't cry over it but I'm not trying to have the baddest thing out there. I just want it respectable and to be able to kick the '03 cobras *** that live down the street
If I have to I might spray it but it won't be a nitrous built engine. A small shot to top it off won't hurt if it is tuned right.
I'm willing to spend what it takes and yes I have realized it is going to be 12 large+ to do this how I want.
