Dart Billet block
What are you trying to do? a 454 isnt big enough? you need 480+ ci?
After a 454, the price skyrockets. It's the stroke that gets you. Achieving that extra deck height. I'd think longativity would be jeoparised aswell with a 4 and a half inch stroke.
Maybe one of the sponsors will chime in on that..
http://www.dartheads.com/products/bl...ll-blocks.html
Found the Billet. Says CALL for price
http://www.dartheads.com/products/ch...let-block.html
On that note, there is really no reason to buy one unless you're wanting to have a serious, competitive, consistent, all-out race application. Even then, you can run a re-sleeved LS2 block, LSX, Warhawk, 6.0, C5R...etc.
Quite possibly. I've been told that more than once, it's been a while since I had a professional mental evaluation, though.
I'll give you a general run-down on the whole car set-up. After the whole project is done, I'll give out exact specs of every single inch and lb. of it.
Engine: 417ci
-Bore: 4.125"
-Stroke: 3.9"
-Twin T-91 Turbo's
-~8.5:1 CR
-Solid Roller
-Back Halved 25.2 Chassis
-Liberty 5 Speed
-3,000 lbs. Race-weight
It will be running Outlaw 10.5 next season. It seems as though we've hit the sweet spot in the 10.5 world
. There is supposed to be several new contendors that are going to be competitive and Tim Lynch's crew claims they're turning up the boost for the 08-09 season......should be interesting.
Engine: 417ci
-Bore: 4.125"
-Stroke: 3.9"
-Twin T-91 Turbo's
-~8.5:1 CR
-Solid Roller
-Liberty 5 Speed
..and what kind of heads are you going to try to shove half the easths atmosphere through with twin 91s?
He has some majior problems with it at 1st..... looks like its back up now.
There are great deals to be had when the timing is right. I wish I had 30 of them to sell right now because they would all be spoken for.
