L92 heads - LS3 intake with 228/232 cam in a LS2 GTO?
Old 09-03-2008, 05:12 AM
  #61
ShoddyHog's Avatar
Originally Posted by Summerwolf
Gerry. All the luck in the world to ya....you sound like you need it.
Thanks. We'll see. Sounds like this cam is going to suck so bad with the L92's, when I pop the clutch, I'm going to go bakwards
Gerry
Old 09-03-2008, 08:08 AM
  #62
ShoddyHog's Avatar
FWIW, here's my cam card...
Old 09-03-2008, 08:35 AM
  #63
WKMCD's Avatar
I might be tempted to install that retarded 3 degrees.
Just my $.02
Old 09-03-2008, 08:45 AM
  #64
ShoddyHog's Avatar
Just my $.02
Cam was installed last year...here's what the installer put on the receipt...remember...I'm a cam NEWB, so I don't understand all these numbers. Hell, I don't even have a degree wheel or anything.
Old 09-03-2008, 08:58 AM
  #65
ShoddyHog's Avatar
And I know you guys will hate me, but it may be October before I get this thing on the rollers....and even if I make it to the track, that's not going to prove anything...I have street tires, and suck at launching my car.
Gerry
Old 09-03-2008, 02:58 PM
  #66
66deuce's Avatar
Gerry
take your time Gerry and make sure everything is right..
and i wasn't trying to imply that your cam is going to be a dog with those heads..i don't have the experience or the working knowledge of your combo to know for sure..just from what i have seen or read about the L92s they like different valve events than LS1/2 heads..but i could be way off,i'm definately not a cam expert...
Old 09-03-2008, 04:15 PM
  #67
ShoddyHog's Avatar
That wasn't aimed at anyone in particular...just being silly / making fun of the wide array of opinions about what does and doesn't work with these heads. I certainly haven't a clue, asked the only person I thought would give me a reasonable answer, and even he refused to answer the question.
So I said to myself, "Self...there's only one way to find out."
That's one of the reasons I'm doing everything like checking the PTV clearance, checking lifter preload, and now trying to find a way to get a LS2 MAP sensor to fit in the LS3 intake. If there's a way to make her run strong without pulling this cam, then I'll find it. If not, I'll contact someone who will sell me a good cam for the heads.
Gerry
Old 09-05-2008, 02:06 AM
  #68
Summerwolf's Avatar
Originally Posted by hymey
The heads come on our cars stock in the L98. Usually we see a 60rwhp gain from small cams as a minimum. Some bigger cams than the one in this car have made the same power but the torque curve is ugly. Probably because of the IVC as you suggest. Flycutting is then a must.
http://www.ls1.com.au/forum/showpost...11&postcount=1
Thats 430 rwhp on a DD add 12% to that figure about 483rwhp on a 218 224 xfi but 112. This isn't a happy dyno either looking at some of the stock cam figures. The xfi lobes have produced some amazing numbers. The synergy cam has a 224 intake, which is the most common here on 6L gives the best of both worlds. Going bigger requires a flycut if u wanna advance it some or run some good comp.
more pics of the OTR intake, that thing looks bitchin
Old 09-05-2008, 07:16 AM
  #69
69LT1Bird's Avatar
LS2 MAP to LS3 MAP pinouts:
LS2:
Pin A - Ground (low reference)- black
Pin B - Signal to PCM - light green
Pin C - 5 volt - purple/white
LS3:
Pin 1 - 5 volts - gray
Pin 2 - Ground (low reference) - orange/black
Pin 3 - Signal to PCM - light green
Old 09-05-2008, 07:49 PM
  #70
Beach Goatxz's Avatar
I'm watching this saga unfold with great interest here and on ls1gto.com.
Old 09-05-2008, 08:48 PM
  #71
Summerwolf's Avatar
I can't I'm not banned, but they made it so my account always says the server is too busy.....
Old 09-05-2008, 10:42 PM
  #72
ShoddyHog's Avatar
Found my answer for the MAP sensor...when I got home, I used grey Permatex. Just checked it and it is setting up perfectly. Looks like it might even last.
Got the heads on without breaking a bolt, valvetrain is in, but rockers need to be torqued...headers on. Tired as hell.
Gerry
Old 09-06-2008, 07:14 PM
  #73
INDIGO 5.3's Avatar
Thumbs up
Glad this turned out good so far Gerry, can't wait to see some numbers. I also can't wait until I get my L92 heads. The cam in my goat is spec'd for L92heads.
Old 09-06-2008, 07:26 PM
  #74
He got it running!!!
(And it didn't blow up)
Old 09-06-2008, 08:25 PM
  #75
Summerwolf's Avatar
He got it running you say? WHERE IS THE VIDEO GERRY? UPDATE??
Old 09-06-2008, 08:50 PM
  #76
ShoddyHog's Avatar
FIRE IN THE HOLE!
She fired right up on the first crank...and the tapping went away after I took her out to break in the lifters.
http://www.youtube.com/watch?v=BuTyJt1i1gI
Took her out for a couple check runs, and it gave me a hard on.
Need to do some tuning tomorrow.
Gerry
Old 09-06-2008, 09:23 PM
  #77
Summerwolf's Avatar
I'll have to wait til I get home from work, but I'm extremely glad to hear it! Hopefully it is all that you want it to be Gerry.
Old 09-06-2008, 11:21 PM
  #78
Brody's Avatar
Originally Posted by edcmat-l1
I may have missed it, but what are we looking at in these three curves? Thanks.
Old 09-07-2008, 06:05 AM
  #79
WKMCD's Avatar
Congrats Gerry...On getting the car running
Not the hard on...
Old 09-07-2008, 06:22 AM
  #80
ShoddyHog's Avatar
Not the hard on...
lol Thanks!
Getting ready to put a pot of cofee on, and go out to do some VE and MAF tuning.
Gerry
Quick Reply: L92 heads - LS3 intake with 228/232 cam in a LS2 GTO?
