L92 heads - LS3 intake with 228/232 cam in a LS2 GTO?
Old 09-07-2008 | 09:39 AM
  #81
ATLSS's Avatar
I love how the sound of the car changes as the lifters pump up....
Nice job Gerry.
And if you need any help with the tune (and you have a wideband) I know just the guy...
Old 09-07-2008 | 10:04 AM
  #82
2c5s's Avatar
Originally Posted by ShoddyHog
and it gave me a hard on.
Congrats and TMI.
Old 09-07-2008 | 06:11 PM
  #83
ShoddyHog's Avatar
Nice job Gerry.
I know someone who can tune too
Got a couple runs in today, but had to work on the idle a lot...Had a BIG problem...she was idling much too smooth, but I managed to get that worked out Sounds exactly like she use to now, but man oh man...you can tell she likes her new lungs for sure.
Got some tuning done today, but she still needs a little work on the VE table...plus I'm feelin' out how much timing she likes. I also need to get my new tires on...fast.
Here's my last log...OLSD...obviously down on power ROTFLMMFAO. Whoever convinced me to try these "truck heads" THANK YOU!!!
Old 09-07-2008 | 08:30 PM
  #84
Ben Diss's Avatar
You may want to take a look at an '08 or '09 C6 stock tune and check out the timing. They like a lot of timing down low, tapering off until you hit peak cylinder pressure (around 5250-5500) and then going back up to redline.
Old 09-07-2008 | 09:23 PM
  #85
xdanny510x's Avatar
i think u could get a lil bit more power if u do more of a degree spilt on the cam .. like try running a 230/244/114lsa or like a 240/254/112lsa
Old 09-07-2008 | 09:33 PM
  #86
WKMCD's Avatar
The intake port's too big, BLAH BLAH BLAH....
Congrats Gerry. BTW: Mine likes close to 30 degrees of lead up top.
Old 09-07-2008 | 09:46 PM
  #87
ShoddyHog's Avatar
I'm right there with you...I was running 29 through most of that pull shown above when she leaned out on me...need to get her some more fuel up there to see if she'll hold that. Can't wait to see what a full 4th pull to redline looks like
Thanks for the tip Ben Diss...I'll check out their tunes.
Gerry
Old 09-08-2008 | 08:01 AM
  #88
ShoddyHog's Avatar
Gawd I love that cam...and with the new heads/rockers, I think it is more quiet under the hood now than it was stock.
http://www.youtube.com/watch?v=aORkvjwg0ok
Gerry
Old 09-08-2008 | 04:09 PM
  #89
ShoddyHog's Avatar
VE tuning is done...verified this on the way home/tire shop.
Gerry
Attached Thumbnails L92 heads - LS3 intake with 228/232 cam in a LS2 GTO?-vetuned.jpg
Old 09-08-2008 | 04:15 PM
  #90
66deuce's Avatar
not necessarily...and that second cam would be waay to big for 364 cubes..
do a search and you'll find cams with smaller splits making plenty of power..
Old 07-04-2012 | 02:48 AM
  #91
low2001gmc's Avatar
MASS seller approved
hmmmm....have wanted to try out this cam with 243s and and see it did well with l92s sounds good to me....
Old 07-04-2012 | 09:21 AM
  #92
LS6's Avatar
LS6
What power it produce
Quick Reply: L92 heads - LS3 intake with 228/232 cam in a LS2 GTO?
