will this engine build work
Old Aug 17, 2008 | 07:39 PM
greinder03's Avatar
Default will this engine build work
ls2 6.0 block
Diamond L92 4.00 bore pistons with Valve reliefs
L92 Heads
6.125 Eagle rods
4.00 Eagle Crank
Texas Speed Giant Cam 248/254, .611"/.613"
will this set-up work or will i have PTV issues
thanks
Old Aug 17, 2008 | 08:03 PM
veee8's Avatar
What is the LSA? But I would reconsider that cam for something a bit smaller.
Old Aug 17, 2008 | 08:31 PM
greinder03's Avatar
well i need to find out what i need to make that cam work, go big or go home. lol
113 LSA
Old Aug 17, 2008 | 08:33 PM
Ryans_pewter_ss's Avatar
By what i've heard l92's make good power with smaller cams.
Old Aug 17, 2008 | 08:34 PM
95FbFormula's Avatar
If you are going to use that cam then do not use L92 heads l92s like a smaller duration cam so you need to be looking at a set of trick flow or afr heads if you are set on that cam
Old Aug 17, 2008 | 10:27 PM
greinder03's Avatar
i was told by texas speed to use that cam with the set-up i was using. they said that cam is for l92 heads. will the l92 net me more than ls6 heads. it either getting ls6 heads or l92 heads. all i need to know if that set-up will work. if not im going with just a stock 6.0 shortblock and throw the heads and cam in and be done
Old Aug 18, 2008 | 03:22 AM
dca1042's Avatar
236/246@.050"114 is still a big stick in a 6lt with l92 heads with manual trans,4000+ conv with auto.go with something around 233/237@.050"114lc .600"and it will hammer.
hope this helps,
cheers dave
vn commodore iron 427,dd,waiting on l92 street warrior.
Old Aug 23, 2008 | 11:31 PM
greinder03's Avatar
well will that cam work with ls6 heads? due to the weiand street warrior never coming out for an l92 so will ls6 heads work so i can use a good flowin intake
Old Aug 24, 2008 | 01:50 AM
jermzz's Avatar
I wouldn't use the texas giant.
I and a couple other people on this forum have used it and not had the best results. Dont get me wrong, it's a a good cam, but only if you're running 12.5:1 SCR or higher.
Other then that this cam will not make the same power that other cams similar to it's size. This is TSP flagship Big cube cam.
If I were you have Patrick, predator or someone who does it a lot spec you out a cam. Whenever you deal with a sponsor, you're gonna end up with an "off the shelf" type cam.
This cam should work with your setup though with valve reliefs. Your engine builder will know for sure.
and FWIW, the texas giant cam from TSP has been around way longer then l92 heads with the same specs. This cam couldn't have been made for l92 heads for that reason. As I said, it's pretty much their only off the shefl Big cube cam they recommend to everyone.
Old Aug 24, 2008 | 07:29 AM
Bring the Noise's Avatar
LG G6X3
23x/24x .6xx/.6xx with a 113 LSA (somewhere in that ball park).
Alot of 402 (LS2 block with 4.0 stroke crank) users have liked that cam along with a set of good L92 heads with the L76/LS3 manifold setup.
There was a post up a week or two ago where someone went from a large cam 24x/25x cam in there 402 down to the G6x3 and found the midrange to have increased and the upper end to have stayed within 5 to 10hp of the larger cam.
The Texas Giant was designed for the LS1/LS6 style heads and if you put that cam into a 402 put the appropriate top end on to go with it (like ET or AFR heads and a fast 90 manifold).
