Bad News
I need to know if coolant has already passed between the heads and block, does that mean the gaskets are toast? I need to know ASAP so I can get some new ones ordered.
Also, I called up Cometic with the information that Steve provided about the different coolant holes between the LS1/LS2 and the LS1 MID sleeve gaskets, talked to a tech guy there, and this was his exact words.
"There are NO other coolant passage holes offered for the LS series motors except the LS7. The ONLY difference between the LS1/LS2 and the LS1 MID sleeve gaskets is the embossing, there is no difference in the location of the coolant holes."
I personally will have to go with Steve on this one, but the tech guy was very assertive about there being absolutely no difference in the location of the gasket holes. Either way, if I have to order new gaskets, i'll get the MID's this time.
So, are the gaskets toast? Or will a re-torquing hopefully seal them back up?
Thanks!
Adrian
i dont think I can do anymore loosening/torquing on mine anymore due to them being stock bolts
I went ahead and retorqued, and its looking to be ok. The studs had backed off slightly after i swapped the gaskets, but like i said, so far looks good.
