Is a 550rwtq LS7 possible?
Old Aug 29, 2008 | 10:35 AM
edcmat-l1's Avatar
Originally Posted by See5
With a LS7 block and ~11.25 CR ported LS3 heads and LS3 intake you will get close to 550 rw tq and hp. (with the right cam). The LS3 heads seem to limit peak hp a bit but the hp/tq # come out about the same. LS7 heads with LS7 intake will make more hp but will not be as "square" re hp/tq.
So 550/550 rw is not difficult but will likely be more than you can use in 1st, 2nd and while cornering in 3rd gear. (AX)
The same engine with intake/carb will make much more hp but the hp gains are almost equal to torque loss.
I'm a huge fan of the L92s. Everyone here knows that. But, if you want to BUILD TORQUE, they would not be my head of choice. For that kind of torque for an NA motor, it would best be suited to smaller cathedral port heads, and a relatively mild cam, with a good bit of advance ground in, or installed a couple few degrees advanced.
Old Aug 29, 2008 | 10:42 AM
Louis's Avatar
I see a lot of tire kickers, but only one graph? This car had a lot more to it than just a heads/cam package. Its the entire combo... Not so much cam, REALLY good heads, good rotating assembly, and every bolt on that could be bolted on...
And no, it isnt easy like everyone says. 530 is very doable around here, 550 is not.
Louis
Old Aug 29, 2008 | 12:16 PM
tlaselva's Avatar
Originally Posted by WKMCD
It's getting harder and harder to find an honest dyno around here. Too many people believing the BS numbers that are thrown out here so easily and the nut hangers piling on but I guess that's what sells. 550 on an honest dyno IS going to be hard and will take a very well designed high compression 12+:1 engine. It's probably not going to be something you'll drive around on the street.
Agreed.
A wise man once said, 'believe half of what you see, and even less of what you hear, and even less of what you read.
Old Aug 29, 2008 | 02:33 PM
LS6427's Avatar
Originally Posted by AU N EGL
Might be a challenge with an LS7 block. Several have tired and succeeded somewhat until the cylinder wall has blown out.
a C5R block, Warhawk or Dart Billet block would be a great starting place for that kind of power.
The C5R and LS7r blocks ( Corvette racing) run ~ 580 BHP and ~640 LBFT ( FLTQ)
493 RWHP isnt alot of power these days at all.
BUT.....a block isnt what makes power. Using one of those blocks is a complete waste of money for just 550 RWTQ.
Old Aug 29, 2008 | 03:48 PM
VGLNTE1's Avatar
hum...I have 440 rwtq and use ported milled LS3 heads on top of a 416 with a 232/246 cam. where in the world does 550 come from?
Old Aug 29, 2008 | 04:24 PM
See5's Avatar
I guess not the same place yours came from?
Old Aug 29, 2008 | 04:38 PM
VGLNTE1's Avatar
obviously not. what is your trap speed?
Old Aug 29, 2008 | 04:48 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Talking
Originally Posted by edcmat-l1
Yep. Its easy. Everyones doin it. Its gotta be true. I read it on the intranet. LOL
ME TOO---that jumble of Tubes is handy....
Old Aug 29, 2008 | 05:09 PM
VGLNTE1's Avatar
and what is a ls3/90 shaner intake? I'm the one that bought the LS3 intake off you on corvetteforum
Old Aug 29, 2008 | 06:03 PM
WKMCD's Avatar
Are these extrapolated DynoJet numbers???
Old Aug 29, 2008 | 07:34 PM
See5's Avatar
The dyno is for a PM forged LS7 with ported LS3 heads and stock LS3 intake and a conservative cam built for this limited street/RR track day car.
This particular car was pulling several car lengths on the "factory" ZR1s a few weeks ago @ Road America.
The dyno is a SuperFlow eddy current which is a dream to VE tune on. I have been able to tune out much of the ~3k torque stall. It does correlate numbers closely with a Dynojet. These numbers are typical of our similar builds which are certainly not dyno queens.
My car is similar except for the stroke and makes a bit more torque commensurate with the extra cubes. HP is about he same, due I think, to the LS3 manifold. The Shaner ported TB is not a big contribtor ~ $-5 HP? Our race car engine however, spins to red line @ 7900 with a modified GA cam and is still gaining power with same long block and GMPP carb setup. Not a suitable street motor, however.
The point is that a conservative build, using carefully chosen, non exotic parts can make a really fun, long lived, "square" HP=TQ motor. Given the intake manifolds we have to chose from, it is not hard to justify.
Old Aug 29, 2008 | 08:07 PM
  #32
red02Hawk's Avatar
Louis
I was hoping Louis would chime in, i have been impressed with the LG ls7 cams from the get-go. In all reality, i will be satisfied with anything over 500rwtq. If you don't mind me asking what was the specs on this motor, mainly the cam. Btw guys its a resleeved ls1 block with Katech main caps, arp main studs, callies dragonslayer crank, compstar rods and diamond pistons, and ls7 heads are going on it. Is an main cap girdle worth it?
Old Aug 29, 2008 | 08:28 PM
  #33
KMS.1320's Avatar
You need a BMEP of around 220 to get a true 550rwtq.
In other words, good luck! or keep going to dyno's until you get one to spit out 550.
Old Aug 29, 2008 | 10:58 PM
  #34
VGLNTE1's Avatar
lol
