Stock Motor 1 3/4" Vs. 1 7/8 Engine Dyno Results!!
After 5 days of engine dyno testing different combinations & packages I'm proud to announce I finally have some extra time to provide you guys with some of the information we've learned!
The very first dyno testing we did compared header primaries & power output from 3000 to 6000rpm. The base engine was completely stock 01 engine with only a Fast intake installed. We dyno tested both the Pacesetter 1 3/4" coated long tubes & the TSP 1 7/8" long tube headers. The goal was to see how the larger primaries would effect power on a basically stock engine. To my suprise the 1 7/8" headers made a considerable amount more power than the 1 3/4" headers! Power output was virtually identical untiL 4800 rpm when the 1 7/8" headers began to outpower the smaller 1 3/4" primaries. The 1 7/8" headers made a peak hp of 414.x hp & 421lb ft while the 1 3/4" headers made 408hp & 419 lb ft of torque. While this isn't a huge difference, it definately shows that even on a basically stock car the larger headers are still a good investment! Power under the 4800rpm point was virtually identical! Infact the 3000 rpm numbers were 209hp 366 tq from the 1 3/4" headers & 209hp 359.9 tq!
Both dyno runs were backed up several times & the combos used very similar air fuels & locked in timing at 28 degrees. I thought this was a pretty cool comparision, because the common thought is the 1 7/8" headers is just overkill on anything smaller than stroker setups. This is apparently not the case....
Here's a few pics of the 1 7/8" headers installed on the engine dyno
![](http://www.precisionracecomponents.com/178dyno.jpg)
The dyno video can be seen at:
http://www.precisionracecomponents.com/178dyno.mpg
I'll have some of the guys help me bust out some detailed dyno graphs for you guys to checkout in the morning.
Enjoy!!
I would like to offer anyone who doesn't agree with these finding to come down to our shop & I will be more than happy to redo any testing we've done over the last 5 days. All our engine dyno testing was done at a independent dyno facility & as long as your willing to pay the dyno testing fees, I'll glady reproduce any testing we've done. This is a very reasonable offer, if you don't want to put your money where your mouth is then please don't jump in this thread & talk crap. I'll gladly defend any testing we've done, I'm always looking for a opportunity to get back to the engine dyno for more testing.
Enjoy!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
From your picture i see that you are running truck coils. Is this something that you recomend?
I am torn about weather to run 1-3/4 or 1-7/8 headers. Do you have any tests from idle to 6k? To see if the bottom end suffers from the larger primaries.
Thanks
Nolan
Thanks
Nolan
This is just what a well known Australian workshop has been recommending for years!
1 7/8"s make more power on everything from stock LS1 engines and right through to massive H/C combos![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
So now here's more proof
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
Sorry guys you just can't put load on the enigne dyno much bellow 3000 rpm. The engine dyno operator tried to talk me out of going 3000rpm!
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
Not disputing the facts and very good test but couldn't collector design differences make up the 6 hp and 3ftlb?
Why not use a set of Kooks or other manufacturer that has both sizes to make the comparison?
LS1Tech Premium Sponsor
We wanted to test the two most popular headers WE sell to give actual data to OUR customers. But, we also tested Kooks 1 7/8" stepped headers as well.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
It is great to see sellers go the extra mile to inform their customers.
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Was checked on the dyno, no changes had to be made.
All set ups are different, like I said-FWIW.
