So now that engine is about done(oil question)
What oil should I run for break in? I know this has been asked a million times, but I was researching and people have mixed feelings on the Rotella T, since the formula has changed.
So I have a couple of questions:
Im gonna pour in the oil tomorrow(or should I pour in right before I start it), because the engine isnt even on the K member yet...
But either way, I have about .1 - .2 qts of oil in now, how much oil should I use? stock oil pan on 402 stroker...
Im thinking I should have in 5 qts poured in start the engine the pour in the other 1 qt. making a total of 6.1 qts... Im thinking about blending in Rotella T(10w40 I think) and the VR1 20w50..
1) are these 2 a good mix? and how much oil to use total?
2) are different oil weights going to give me a problem?
3) basically what steps should I take for break in? type and amount of oil, go WOT in higher gears to load the engine, etc? of course after the car is fully warmed up.. Im confused what to do the first time I take it to drive, right after I start it and let it warm up..
besides I plan on changing the oil after the first 20 or so miles, then installing more of the same blend for another 100mils, then after that 500 miles. after that 1000 miles...
is this a good plan?
tell me what I need to know, thanks..
I think Ill have my engine on the K member, mid week, next week and running by next thursday(9-18-08)
Once you start it, it will be between 5-7 seconds before you'll see the oil pressure build. The recommendation that DrkPhx made as far as oil is a good one, I would also add the GM EOS or Red STP additive for some extra anti-wear additives, and better ring sealing.
Run the first oil change for Start-up ONLY, let the motor get to full temp. Drop the oil and filter, then refill, and put in new filter. Run for 500 miles, make sure to put some load on the motor ,and make sure you're not running too rich or lean (tune/get tune asap). DO NOT RUN THE MOTOR WITHOUT A TUNE, you will ruin it.
Change oil after those 500 miles, refill, new filter, and run for 1000 miles. Drop oil, check metal content (make sure its atleast less than before). Refill, new filter again, check coolant level to ensure gaskets are sealing properly, and run for 2,000 miles. At this point you shouldn't be seeing any metal. Finally, fill with your prefered oil/filter. I would recommend 6 qurts VR1 20w50, with a pint of Red STP additive and a KN 2006 (i like the higher capacity filter, and it does not extend past the headers) oil filter. I've run RP, mobile 1, and other oils, and so far, I've liked the racing oils (20w50) weights MUCH better as they hold up to the higher oil temps we'll see with these higher hp motors. You can try the XPR oil, but VR1 works well, and is 1/4 the cost.
sorry, but Im not a total newb to building engines.
Also, Warm up the motor and then change the oil? sounds wrong to me, without any load the rings arent gonna expand that much , I will drive for a good 20 miles with variable load and change oil and filter, that to me sounds more reasonable..
and I dont have a tune for my car, how can I have a tune for it when its a specific bild, I have my old head cam tune and thats good enough to break it in, then Ill get a tune, once I feel my rings have seater properly..
I wanna hear more input on this from other people, thanks
This is definitely a step I don't skip with any engine I build.
The breakin procedure I described is IMHO the best procedure.
First off, there is no difference between turning over the engine before starting it, than just starting it. You're still turning it over regardless, except you keep the oil pressure you built by turning it over and starting it right away, make sense? Its pointless to turn over the motor with the starter, get out, plug everything back in, and then turn it over again to start it.
Warming up the motor, and then changing the oil is not wrong by a long shot. You will have lots of metal after the first run, and its best to get that out before you drive the car around. Running the motor without any "load" to warm up will not damage the rings, nor keep them from seating, thats just silly. Besides you want to make sure everything is in order (no fuel leaks, no header leaks, no abnormal noises once warm etc...) before you want to take it out and start loading it up. If something is not right, you'll catch it before you roll the car down the street.
As far as the tune, I didn't mean a perfect specific tune that you just start up and run forever. i was more referring to a starting point tune, such as ensuring that your injector flow rates are adjusted for new injectors, and that VE tables are set to reasonable levels. Running a stock tune will/could damage your motor, running too rich causing the rings not to seat and glazing the cylinder walls etc...
Also, don't wait to get the tune, get it tuned right away, because who knows what AFR's you'll be running once you "feel the rings have seated properly..." if you don't have a wideband hooked up, seriously. For all you know you could be running pig rich and wam, time for a rebuild. The rings will seal on the dyno, guaranteed.
Sorry if you don't want to hear my advice, but I feel I should share,
Best,
Adrian
We have also found that Amsoil works good for a short time and then breaks down (dyno showed that). Royal purple is also a great option as well.
The main thing is to make sure that your rings are broken in before switching over to synthetic.
Lastly, you have to disconnect the injectors (coils as well if you dont' want spark running either) if you plan on priming the motor, otherwise you'll have unburnt fuel in the cylinders after you turn it over 3-5 seconds, flooding it, not a good idea.
Best,
Adrian
No actually, the part where I could catch a mistake, when I let it warm up, then changing the oil sounds like a good idea. so I will do that..
also it makes sense to disconnect the injectors as well, duh I wasnt thinking because I didnt realize the fuel will still be there..
thanks
once im set there my tuner is kind enough to stop by for a start up tune so i can drive to the dyno to let it eat!!!
i plan on....... warm it up to check all fluids and clutch.
drive a few miles (8) to the dyno
dyno tune it
drive home
have fun for 500 miles
run it for 2000 miles
change oil and filter to my favorite synthetic
you will build oil pressure with just the starter. it builds its pretty fast with no accessories spinning or plugs.
my engine builder said it wasnt nessessary to prime it i did more for a middle of the build check. i does take a little worry away though when that needle shoots up!!!!
my builder said plain jane castrol 10 w 30 so thats what im using. spdc recomends rotatilla. and everyone else a different brand also. personly since the oil is in for so little time in the beginning of the motors life you could get by with any conventional oil. just add some gm eos for some mental reassurance(i got a 16 0z bottle to go in after my warm up change).
good luck, have fun and post your results!
could you elaborate on the amsoil wearing down?
I found out at last years SEMA show, I met Jody Davis one of the owners of Torco. He had told me quite a bit about thier product.
I'm going to have a LS something built next year, and I'm not sure which oil I will be using. If I can get a good deal thru Jody, I'll run Torco again. I've never had a problem with their product in my dragster, so hopefully he will help me out.
Either way, go with what you know. I don't get paid from any of these guys, I'm just sharing what I have done in years past.
Hope this answers your questions
