Modified LS3 vette owners come in
Old Sep 20, 2008 | 10:21 PM
Bad93TA's Avatar
Default Modified LS3 vette owners come in
A buddy of mine just got an 08 vette with the ls3. He put a cold air intake on it and OnStar kept calling him because his check engine light stays on. How do you guys get around this? Tune it out of the comp??
Old Sep 20, 2008 | 11:10 PM
Summerwolf's Avatar
did he disconnect the battery cable and make sure all the clamps are tight/sensors plugged in?
Old Sep 20, 2008 | 11:16 PM
Bad93TA's Avatar
Im not sure he just said after he installed it OnStar kep callin him becasuse his check engine light was on so he took it off. Im sure he installed in correct. If he didnt disconnect the battery the check engine light would come on?
Old Sep 20, 2008 | 11:20 PM
Summerwolf's Avatar
the battery disconnected will clear the code and upon startup the computer will learn the new parts....sometimes it works sometimes it doesn't.
Old Sep 21, 2008 | 12:04 AM
Bad93TA's Avatar
and if it doesnt??
I just realized i put this in the internal engine section. Mods feel free to move it... sorry
Old Sep 21, 2008 | 12:16 AM
abbaskhan's Avatar
we had the same problem but onstar has yet to call car even studdered bad it seems o8 computer is SENSITIVE
Old Sep 21, 2008 | 12:32 AM
Bad93TA's Avatar
hmm did you disconnect the battery like Summerwolf said?? Im going to tell him to try that...
Old Sep 21, 2008 | 07:01 AM
AU N EGL's Avatar
disconnect OnStar
Old Sep 21, 2008 | 11:02 AM
Bad93TA's Avatar
Originally Posted by AU N EGL
disconnect OnStar
How do I do that? And what if he really has a problem, can he reconnect it?? Did you have this problem also?
