What the hell? my rockers keep breaking the pedistools
Old Sep 26, 2008 | 04:23 PM
LSGunZ28's Avatar
Default What the hell? my rockers keep breaking the pedistools
My rockers (Harland sharp rebuilds) keep breaking the pedistools when I torque them to 21 ft lbs....
I did it very carefully this time and I checked and it nicked a small groove in certain pedistools...
cyl #1 intake and Cyl #7 exh
Cyl #2 exh and Cyl #4 intake... so far, I havent checked the rest of the even side...
Im gonna rotate the crank every time I torque them so the valves will be closed, this is the advice I was given..
anyone experience this??
I wasnt gonna make a thread, but i went through 2 brand new pedistools already...
Old Sep 26, 2008 | 05:39 PM
vettenuts's Avatar
What procedure are you following? Here is GM's:
Old Sep 26, 2008 | 07:09 PM
LSGunZ28's Avatar
How can I tell if the #1 piston is at TDC of compression stroke?... I cant see through the ports...
edit:
Holy crap, I just tightened them from inner to outer...
Ok thanks
I will post pics of my pedistools. I wonder if they are okay for use still...
Ill let you be the judge after I post the pics..
Old Sep 26, 2008 | 07:33 PM
vettenuts's Avatar
Watch the pushrod on the intake for #1, when it comes up then goes down bring the piston to the top and you will have the first TDC position in the procedure.
Old Sep 26, 2008 | 09:11 PM
LSGunZ28's Avatar
Hey man thanks a lot..
Im still gonna post my pics to see if I can reuse the pedistools...
Old Sep 28, 2008 | 01:15 AM
LSGunZ28's Avatar
here is the pics of the pedistools... can I reuse them??
Attached Thumbnails What the hell? my rockers keep breaking the pedistools-img_1117.jpg   What the hell? my rockers keep breaking the pedistools-img_1002.jpg   What the hell? my rockers keep breaking the pedistools-img_1118.jpg   What the hell? my rockers keep breaking the pedistools-img_1122.jpg   What the hell? my rockers keep breaking the pedistools-img_1121.jpg
Old Sep 28, 2008 | 02:24 AM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
With the imprint of the fulcrum in the aluminum pedestal and looking at the other pics with the bolts at varying heights, are you sure you don't have some of the rocker fulcrums upside down? They will rotate a full 360 degrees, so the pivot can easily be installed wrong if you don't pay attention to its orientation.
Old Sep 28, 2008 | 02:33 AM
-Joseph-'s Avatar
Red circles look like the bolts aren't tightened all the way or the fulcrums are upside down. Green is the correct orientation. Its hard to really tell from pictures, so just double check those two.
Old Sep 28, 2008 | 06:56 AM
Gimp98TNT's Avatar
You got some of the fulcrums upside down. Thats whats leaving the imprints on the pedestals. I would still use them, just get them installed correctly and you should be good. As long as there not cracked that is.
Old Sep 28, 2008 | 03:00 PM
LSGunZ28's Avatar
I wasnt even aware of this.. I thought (like my YT ultralites) they can be installed any way...
thanks for bringing this to my attention...
By Brett Foote | 2026-06-04 05:00:17
