Generation V External Engine LT1 Bolt-Ons | Intakes | Exhaust | Ignition | Accessories
Gen V with 4l80e
Old Jul 6, 2020 | 11:28 AM
DMACNWA's Avatar
Here is some information on the flex plate that TCI uses and adapter flange
https://www.hotrod.com/articles/15-m...scle-car-swap/
Old May 28, 2021 | 10:07 PM
Bmiller2020's Avatar
Originally Posted by CapriceLS
If anyone is looking, i have the flexplate and snout to run a 4l80e behind a gen V block. Never ran, just mocked up. Cost $400. I'll sell for $250 shipped
would you happend to still have this or know where to get one?
Old May 28, 2021 | 10:33 PM
CapriceLS hasn't been here for over 2 years
Old Jun 28, 2022 | 10:21 AM
dill30705's Avatar
Default Check out my working combination thread.
https://ls1tech.com/forums/generatio...lex-plate.html
Old May 26, 2023 | 07:37 AM
Brialgon's Avatar
Anyone familiar with what needs to be done to mate a 4l80e to one of these gen v's? I know with the LS swap I had to run that adapter/spacer with the flat flywheel but the gen v crank flange is 8 bolts whereas the LS is 6.
Do you still have it? I'm interested
Old May 26, 2023 | 07:48 AM
dill30705's Avatar
this is the factory GM part number 19125597. I don’t believe you can buy flywheel and adapter separately that I found.
Old Apr 17, 2024 | 06:34 AM
Concrete72's Avatar
im interested send your contact information
Old Apr 17, 2024 | 09:37 AM
Read my comment in post 23. Only now it's 3 years more....
Old Sep 23, 2025 | 05:46 PM
truckdoug's Avatar
While the top bolt is not 100% required, the new FI New Power direct mount SFI bell now has the offset LT top bolt at my recommendation. PM me if interested in one.
