PWM (brushless) Rad fan
Thanks,
Sean
Andrew
Thanks again,
Sean
It seems that GM tends to favor large single fans these days. Also check out the Cadillacs, ATS...CTS...and the little SUV...XTS? Whatever happened to cool car names?! :-)
Andrew
This is seriously frustrating enough to just buy a kit, use the fans and throw the rest in the bin lol. I was searching all kinds but trying to get dimensions or CFM ratings is tough. Now that I looked at my Speartech wiring harness I noticed a PWM fan wire so now I have to call them and see what that is for???? I'm getting over my head with this, I'm more of a fabricator or a bolt turner lol.
Thanks for what you've given me so far, it looks like I might have to walk through some dealerships with my tape measure.
Sean
Sean
Don't get frustrated. Have a look at Rockauto. They generally have pictures and often have dimensions. I also have a SPAL catalog. I'll look at it when I get home and look up some dimensions for you. If Speartech did the harness then you should be good to go. I'll post more info when I get on my laptop.
Andrew
I was scouring the Rockauto website lol.
https://www.spalautomotive.it/brushl...0p-n-94a/36647
edit: I'm such a dummy, I looked at the Wizard site but didn't scroll down all the way. They have all the specs here:
https://wizardcooling.com/spal-brushless-fans/
I also think a large single is more efficient and probably quieter as well. I use a C6 fan on my Cougar with the C6 fan controller. The new fans have the controller built in.
Andrew
Looks like 14" by 3" deep 600 watts and the Camaro is 17" and 800 watts but not sure of the depth. I think I can make the Camaro one work if the fan is the same depth.
Sean
Sean
All that sounds correct. I think the Camaro fan is the same as the Cadillac fans. Eight hundred watts is a beast. If you can fit that, go with it. Make sure to run 8 gauge wire for power and ground. That fan will draw 57 amps at 14 volts. I've seen the power wires on a Camaro and they were definitely bigger than 10 gauge. I'd run the power connection through a 60 amp circuit breaker...maybe even 70...maybe 80...even.
In all honesty, I think the C7 600 watt fan will do the trick for you. The C6 fan that I am using is 400 watts.
Also, keep the full stock plastic shroud. It has holes and flappy doors, so that when your moving air can pass through it. I always do a face palm when I see people building shrouds that fully block off the radiator with the air being pushed solely through the fan opening. You don't want to do that!
Good pictures of the C7 fan here:
Here is the SPAL mating connector:
This is a Yazaki connector, USCAR standard, found on a lot of vehicles.
Andrew
Used C7 fan seems to be $300 or so.
12" Delta PAG brushless fan with the standalone controller and probe sensor is $379.
Without the controller (PWM controlled by your ECU) is $305.
They put out a very impressive amount of air and draw extremely low power, 1750 CFM for the small 12" at a fair bit fewer amps than a comparable SPAL.
They're also less than 3" thick at the max.
I'm putting 2 of the 12" on my Corvette and the Nova is probably getting a single 16".
Andrew, I think you're right, the Camaro will be a bit to big and probably unnecessary. I was thinking with such a tight engine compartment and bush bumper, winch etc it would be good to get as much as possible but then again it's a 5.3, not a 6.2 so C7 is probably enough. I think with that shroud it will be too thick but I'll have to take some final measurements once I get the radiator from Ron Davis. I can fab the flappers on a custom shroud easy enough (that kind of thing is easy for me, unlike the tech stuff lol).
Now another question. Does that wire in my harness mean the fan is controlled by my ECM (E92) and I don't need all the extras??? You guys are going to have to start billing me for info haha. I've found a couple of long threads on this elsewhere but it seems to be confusing me more.
Thanks in advance,
Sean
Thanks in advance,
Sean
The fan in my Cougar rarely goes about 50%, but I have a hole in the hood which helps a lot. I also do this with a Holley Dominator ECU, but the principle is exactly the same.
Andrew
PWM signal directly from an ECU works.
