Generation V External Engine LT1 Bolt-Ons | Intakes | Exhaust | Ignition | Accessories
A/C Compressor question
Old Nov 16, 2025 | 10:40 AM
dw456post's Avatar
Default A/C Compressor question
On a 2015 L83, can I mount the compressor so it runs in reverse rotation. I can mount it---but will it work. I see a couple of the Sanden compressors will run in reverse---kinda like an alternator The Compressor is the original GM with a made in US tag. Thanks
Old Dec 15, 2025 | 04:49 PM
SaudiSpeedLS2's Avatar
AFAIK ACDelco (GM) Compressors are directional, but Im not 100% sure. You should check the label (if there is one, and you haven't done so already) to see if it says anything about direction
My question is, how will you get it to turn the opposite direction, and why?
