Why is it called an LT1, again?
OH! and the 91 Corvette does not have a digital dash, 84-89 did. The digital dash although outdated now was very well received as new tech when it came out.
That was like going from a stagecoach to USS Enterprise warp factor **** you.
1). Buy Neglected car.
2). If car isn't neglected, neglect it (pressure washing the front of the engine is a good start)
3). Heater core clogs up, FM radio channels are fuzzy-blame the opti.
4). Replace the opti with a cheap aftermarket opti (bonus points for installing it wrong)
-See also "Pay Dealership to install opti"-
5). Wait for cheap Opti to fail
6). Repeat steps 3-5 as necessary
7). Get mad about money and time 'invested'
8). Sell LT1, Buy LS1
9). Talk about how much faster the mid 13 second car is than the high 13 second car.
9). Pat yourself on the back
10). Talk **** about LT1 on the internetz
Yea I can see that..is that with the Impala SS or the ones with the Baby LT1?
In 97 I bought a 94 and went through 3 optys .
Word on the street is the 96-97 vented optis were a lot more reliable. Not sure if fact or opinion though.
So why after 15 years and finally achieving name recognitions for the LS did GM change back to the LT? Same reason they needed a bail out I suppose.
PS. LS (LS6- 396c.i. / LS7- 454c.i.) engines started in the 1960's, not in 1997
So people have been used the the LS moniker for over 40 years, not 15.The GEN III LS motor 3rd Coast is referring to, came out in 1997 in the corvette, do the math, it is actually 16 years
I agree, the GEN III LS motors had more problems than the GEN II LT's. The GEN II LT motor has nothing to be embarrassed or hang its head about, I'll never understand why people hate on them so much.
And If you get any moisture in any distributor, it tends to not run well lol. This is not an LT1 specific issue, and humidity is a new one to me and I live in Iowa lol. If a car sat for a long time with moisture in the distributor it can rust cause issues of course, but the 95-97 are vented and tend to clear up very quickly if it's an issue (unless you park them in the back yard in the rain for a few weeks without starting it? idk) and the 92-94 optis are sealed so idk how humidity would even effect those at all. Either way, I'd file that under neglect. Same with an overheating or damaged leaking water pump.
As for the Opti going bad, IMO it is ABSOLUTELY neccessary to replace the water pump at the same time. These cars are getting up in age and miles, you don't want to spend all that time replacing an opti to just have your water pump leak all over it a month later and ruin it.
And what other people said, you need to replace both the water pump and opti with GM or A/C Delco parts. I've been burned by cheap "patent" parts made in China on a couple of different occasions.
