No Oil Pressure
There should be a plug on the driver side of the block near the front of the engine close to the oil pan. Undo that plug and pump some oil in there. It sounds like the oil pump isn't primed.
Have you pulled the oil pressure sender and connected a mechanical gauge to see if you are actually having zero oil pressure?
In our case, we chose option two. Even after putting roughly 9 quarts in the engine it didn't prime just turning it over with the starter. I assembled the engine myself and measured clearances so I knew everything was good and I was very generous with assembly lube, so we made the decision to start it up. Fired right up and after a few seconds oil pressure came right up. No issues whatsoever in 10k miles. Just know you do that at your own risk.
And yes I know these aren't gen5, but same principle.
