Generation V Internal Engine 2013-20xx LT1
VVT delete limiter lockout information wanted
Old Apr 2, 2020 | 05:21 PM
thebeewantsboost's Avatar
Originally Posted by G Atsma
Gotcha. In that case stick with lifts around .550 and use LS6/3 springs.
206/212 .510"/.510" and lt1 springs.
Old Apr 2, 2020 | 05:31 PM
That too will work...
Old Apr 3, 2020 | 11:23 AM
00pooterSS's Avatar
It's too much lift when you don't want to worry about replacing valve springs routinely. I'm not talking about drivebility.
Yeah .635 is a lot, and if I recall some of them even run .645
However I'm not sure if a lot of lift with the right spring wears it out more. For example I don't know if a aftermarket spring with a 600 lift cam will wear faster than a OE style spring with say 525 lift. I figure springs wear regardless and ramp rates likely have more of an effect than actual lift.
I read a discussion one day that was pretty interesting where they said higher lift is actually easier on some of the valve train components (springs included) because the higher lift has (in general) a smoother arc across the lobe from open to close. For example on that you may see more of a jump off of the seat then kind of a flatten out of the lift then the off ramp on a lower lift versus a smoother arc from open to close with higher lift. It's going to be very subjective of course. In other words with some low lift lobes, that get the valve off the seat early you may see more of a squared off shape of the lobe versus a more consistently smooth arc.
I figure that ramp rates (rapid collapse of the spring) coil bind and float are the worst killers. And high lift with a smooth actuation can allow springs to live for quite a while. But I also see how high lift isn't necessarily nice to a spring. I don't know, I'm not a guru here. Just regurgitating info.
I never have come across any threads where people have discussed valve spring life where they tested different ramp rates and lifts etc. It would be cool to see. On the flip side, i've seen many broken springs with stock cams.. Had it happen on 2 of my personal vehicles in the past. One was my fault for turning up the rev limiter at 140k miles and living on that limiter every day for way too many miles.
Old Apr 3, 2020 | 12:09 PM
00pooterSS's Avatar
I do know one thing though about gen 5 and vvt. There's a ton of videos and info, and parts available on phaser limiters. So the cams are out there that allow at least some vvt.
I'm glad this post came out though because for some reason I really thought the TSP cams allowed vvt now I have to rethink my future plans..
Old Apr 8, 2020 | 08:21 AM
I asked tsp about needing to routinely change valve springs with their cams and they recommend doing so every 30k.
Old Apr 19, 2020 | 12:42 AM
pmoore4321's Avatar
Who makes this cam?
Old Jul 4, 2020 | 10:36 PM
Fast6.3's Avatar
If BTR's cam is non VVT it attaches with 3 bolts. The VVT sprocket attaches with a big hollow bolt. Do a little homework and read some books on LS engines. You have a lot to learn, as the rest of us have already.
a vvt cam wiht a lock out is basically a non vvt cam it wont advance or retard
Old Jul 4, 2020 | 11:52 PM
Originally Posted by Fast6.3
A VVT cam with a lock out is basically a non VVT cam it wont advance or retard
Most lockouts limit rather than eliminate timing adjustment. If you're totally locking it out you might as well put a normal cam, timing set, and front cover on.
Old Jul 8, 2020 | 11:07 AM
kinglt-1's Avatar
On Gen5 engines, Most shops are now using the zero degree lockout that eliminates any VVT adjustment and it still allows the use of the factory cam phaser. Even the 4 degree limiter kits were showing odd behavior at high RPM. Contact GPI or Brett Stewart for more info on it.
